power rating ques
Discussion in 'General Electronics Discussion' started by burassu, Mar 4, 2012.
  1. burassu
    burassu
    36
    Jul 1, 2011
    Hi I need to know what type of components I need. I am trying to switch on a heat emitter ceramic heater and an under tank heater both work at 50 hz and 230v . but the ceramic heater is rated at 150w and the under tank heater at 25w. What power rating should the resistors be ?? pls
    I was going to try figure 9 of this datasheet
    http://www.soiseek.com/FAIRCHILD/MOC3022M/6.htm
    TNKS
  2. (*steve*)
    25,482
    2,830
    Use the circuit for 240V mains and it is almost certain that the loads are not significantly inductive.
  3. burassu
    burassu
    36
    Jul 1, 2011
    resistors rating
    Therfore I should use figure 9 with a quarter wat resistors on the hot side ??
  4. (*steve*)
    25,482
    2,830
    Sorry, yeah, 1/4 Watt should be fine for the gate resistor(s). Here is a page that describes how to determine the power (it's very low)
