Power rail names
Discussion in 'General Electronics Discussion' started by Tha fios agaibh, Sep 8, 2016.
  1. Tha fios agaibh
    Tha fios agaibh
    2,112
    713
    Aug 11, 2014
    It seems odd to me some of the identifying terms used for power rails; like Vcc or Vdd.
    Yes, It makes sense when more than one collector or drain are similarly connected to the positive rail, but what about when you have a circuit with both mixed bjt and fets, or mixed N type and P type transistors on the same rail? (For instance both a drain and a source connection to the same rail) What's the criteria for properly identifying them?
    John
  2. davenn
    davenn Moderator
    13,669
    1,891
    hey John ... Mainly because it isn't really used as a device specific thing as you are assuming
    that is ... Vcc is very commonly used to denote the positive rail regardless of the circuit type or components within
    have a read through .....
    https://en.wikipedia.org/wiki/IC_power-supply_pin
    here's an interesting response on another forum .....
    am sure there's more comments out there
    Tha fios agaibh likes this.
  3. Tha fios agaibh
    Tha fios agaibh
    2,112
    713
    Aug 11, 2014
    Thanks Dave, makes sense.
  4. OBW0549
    OBW0549
    159
    118
    Jul 5, 2016
    No criteria, really, nor any "proper" usage; they are just a commonly-used naming convention that helps us quickly and intuitively determine what kind of voltage, positive or negative, they represent. When I see "Vdd" or "Vcc" I expect a positive supply voltage; and when I see "Vss" or "Vee" I expect a negative voltage.
    There's really little more to it than that.
  5. Tha fios agaibh
    Tha fios agaibh
    2,112
    713
    Aug 11, 2014
    Thanks. I was wondering because It's possible to have the opposite polarity depending on transistor type.
    Another thing that seemed odd to me, is how a N type mosfet has its "source" connected to Negative and its drain hooked to a positive source.
    I will try not to overthink this stuff.
    Lol.
    OBW0549 likes this.
  6. OBW0549
    OBW0549
    159
    118
    Jul 5, 2016
    Yup. Just accept the conventions for what they are: conventions. (It's probably a good idea to follow them, too; if someone sees a negative supply voltage labeled "Vdd" their head will probably explode.)
