Power Pin USB PCB ripped out
Discussion in 'Power Electronics' started by NVZN, May 11, 2021.
  1. NVZN
    NVZN
    17
    Dec 17, 2016
    I was doing replace switches in my keyboard.So i pull out carefully the power USB socket out. Then when done replacing the switches, i was going to re attach the power USB to the PCB. The power usb socket is JST type 5 pin (i assume), and i feel something weird.. the socket felt loose and moving and...it ripped.
    I was surprised that how that easy to yanked out, even i did carefully pull and re-plug.
    I did photo macro, how to fix this? i heard scrape the coppers.. which coppers?
    [​IMG]
    Better lighting :
    [​IMG]
    I did a concept, does it work? ugh these things so small... what cable i can use to jump these?
    [​IMG]
  2. Harald Kapp
    11,417
    2,619
    Your concept looks good.
    Here's my visualization:
    You can use the remains of copper at the ends of 3 pads (green rectangles). For the other pads you'll have to find the ends of the broken traces and reattach them on both sides. Use Epoxy or hot glue to fix the connector to the PCB once you have verified that the electrical connections are o.k. Not before as you may have to remove the connector and try again until all connections are good.
    Martaine2005, NVZN and PETERDECO like this.
  3. NVZN
    NVZN
    17
    Dec 17, 2016
    Hello! I just did this :
    [​IMG]
    [​IMG]
    And it works again! phew... kinda ghetto though, but i eye ball it 5 times, to make sure it's not shorted. The keyboard turns on normally.
    [​IMG]
  4. Harald Kapp
    11,417
    2,619
    Images don't show. Good job anyway.:)
  5. Martaine2005
    Martaine2005
    3,408
    926
    May 12, 2015
    Fantastic photos BTW.
    Out of curiosity, what size are the photos?
    Martin
  6. NVZN
    NVZN
    17
    Dec 17, 2016
    only 2 mb. OMG i just realized the photos dont show up....
  7. NVZN
    NVZN
    17
    Dec 17, 2016
  8. narkeleptk
    narkeleptk
    43
    11
    Oct 3, 2019
    it will rip off again very easily so be-careful
  9. NVZN
    NVZN
    17
    Dec 17, 2016
    yes indeed, thats why i will never detach the cable port again.
  10. narkeleptk
    narkeleptk
    43
    11
    Oct 3, 2019
    With out some support like glue or being taped down it may detach itself but that is a bridge to cross when it happens I reckon. good job on getting it working again!
  11. davenn
    davenn Moderator
    13,808
    1,943
    for uploading here, keep images to ~ 100kb and around 1000x768 pixels maximum
