weatherjack
- Dec 9, 2011
- 15
- Joined
- Dec 9, 2011
- Messages
- 15
This should be simply but I am drawing a blank on this? I am building a project that has 24v input and 24v output. I have a toggle switch I want to use to turn the power on and off. I also have a green LED (on) and a red LED (off). When the power is on I have a push button switch to allow 24v to output. So I plug in the 24v input, toggle swich is off, red light is on, push button will not work, 24v does not go to output. I plug in 24v, turn the toggle switch to on, the green LED will light up, push button switch sends 24v to output. This should be so simple I have been away from electronics for some time and now getting back into things. I just simply cannot figure this out? If I get this problem worked out I will share the final project with pictures.
