power on delay circuit
Discussion in 'Electronic Basics' started by chitta, Mar 6, 2008.
  1. chitta
    chitta Guest
    Hi
    my name is chittaranjan.
    I need a waveform with power on as follows
    1.HIGH for 1 sec
    2. LOW for 2 sec
    3. HIGH permanently
    Please help me obtain this waveform without using any microcontroller
  2. Chris
    Chris Guest
    Read in fixed font or M$ Notepad:
    | VCC
    | 1uF---
    | | |\ ___
    | .---o---|H>O--|<--|___|.
    | | | |/ 22K |
    | - | |1M |
    | GND GND |
    | 3/6 74HC14 |
    | VCC VCC |
    | - | |3M |
    | | | |\ ___ | |\
    | '---o--|H>O-->|--|___|-o--|H>O-
    | +| |/ 220K | |/
    | 1uF--- 2.2 M| |
    | GND |
    | GND
    (created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
    Requires 1/2 of a 74HC14 (or 74C14 if you're using a power supply of
    more than 6VDC), 2 1uF caps, 5 resistors and four 1N914 diodes. If
    your power supply takes more than 10ms. to charge up and discharge,
    you can lose the two protection diodes.
    Simple, not elegant or precise. Your timing on this may vary by quite
    a bit.
    Good luck
    Chris
  3. JeffM
    JeffM Guest
