Power Inverter
Discussion in 'General Electronics Discussion' started by kash kimmich, Feb 18, 2015.
  1. kash kimmich
    kash kimmich
    Feb 18, 2015
    If anyone can help me please let me know. I have two powered speakers that takes (ac 120v 50-60hz 108va max) each and one subwoofer that takes (ac 110-120v 50-60hz 100watts) I need a power inverter to power all three of theses appliances but I don't know what kind of inverter I need. If it helps I'm installing it all in my boat with 3 deep cycle marine batteries.
  2. mofy
    mofy
    46
    14
    Dec 19, 2014
    Total power is 300 watts. It's either 12v dc or 24v dc to 110v AC @ 60Hz, depending on whether you have 24v or 12v dc in your boat. At 12v and full load your current will be around 25A. Such a system with the sound turned up can fairly quickly flatten your batteries.
  3. swagguy8
    swagguy8
    73
    6
    Dec 10, 2014
    i agree, unless the boat's motor is running.
    Your boat needs a 120v inverter that supplys adequate wattage to your system, so if ur system needs 300 watts, then put in a inverter at least 1.25x the required power.
  4. kash kimmich
    kash kimmich
    Feb 18, 2015
    So would a 700w 12v dc to ac 120v 5-15R 3 outlet power converter work?
  5. swagguy8
    swagguy8
    73
    6
    Dec 10, 2014
    that would be perfect,
