Power indicator LED for 50v+ supply
Discussion in 'LEDs and Optoelectronics' started by CommanderLake, Aug 12, 2019.
  1. CommanderLake
    CommanderLake
    196
    6
    Oct 2, 2012
    I would like to have an indicator LED for the output of a boost converter but a simple resistor>LED would consume about 500mW and require a relatively large 1W resistor and I really don't want to use so much power just to see that the output is live.
    So Is there a solution that would use less power without taking much more board space?
  2. Harald Kapp
    10,025
    2,138
    Quite a few, I say.
    1. Use the low input voltage of the converter to drive the LED. Sense the output voltage using a comparator and turn on the LED if the output voltage is o.k. (example).
    2. Use a 555 timer chip to pulse the LED if the output voltage is o.k. Pulsing will reduce the average current.
    3. Use a 555 timer as above (#2) but use an output inductor in series with the LED to create a kind of primitive step-down converter.
    4. ...
  3. CommanderLake
    CommanderLake
    196
    6
    Oct 2, 2012
    I already considered a BJT and suitable resistors but board space... its only an indicator LED, I dont want a relatively large 555 circuit.
    Keeping in mind I have to be able to solder the components with a standard soldering iron.
  4. Bluejets
    Bluejets
    4,056
    847
    Oct 5, 2014
    Run the LED at 5mA with a 10k resistor ....in most cases it would be sufficient brightness for an indicator.
  5. Alec_t
    Alec_t
    2,822
    754
    Jul 7, 2015
    You might even get away with 47k and 1mA if the LED is a modern high efficiency type.
  6. CommanderLake
    CommanderLake
    196
    6
    Oct 2, 2012
    I've selected this LED but its the brightness for a given current I'm not sure about, I think I will go with 10k on the output as Bluejets suggested and 2.2k on the input, I just need the output LED as a warning that its armed and dangerous.
  7. Harald Kapp
    10,025
    2,138
    Acc. to the datasheet the LED will light up with as little as 1 mA. Simply test whether the intensity is good enough for you.
