R
Roque
If I have a power supply similar to a computer power supply where it's
rated at 300W, what is the proper way to figure out what my actual power
usage is when I have this system running under its maximum load?
Here's what I've done so far....
I have a power supply that provides 24.5 volts and 5.1 volts DC output,
I find I can run a total current of 9 amps continuous, or 20 amps peak
before tripping the internal protection.
When I put a current probe on the 24.5 and 5.1 volt lines,
using a digital scope with math functions, I get 8 amps RMS on the 24 volt
line and 1.15 amps RMS on the 5.1 volt line, in my worst case use of the
machine.
I'm trying to decide what power dissipation I have...
With my scope, I saved 30,000 points of voltage and current data against
the same time line, and I
imported this V, I data to a spreadsheet....and created a new calculation
where I multiplied V * I for each data point...for instantanious power per
sample. I then squared each V * I data value, summed it, divided by 30,000
samples, and took the square root...hoping to find RMS power.
With 8 amps at 24.5 volts and 1.15 amps at 5.1 volts, I found about 200W
power dissipation...
Does this make sense? I'm not experienced with "power" electronics to be
confident about it so I wanted to seek advice.
Thanks.
machine.
Thanks.
