RFEverywhere
- Jul 25, 2014
- 1
- Joined
- Jul 25, 2014
- Messages
- 1
Gentleman (& Ladies??),
I require some help.
From what I have read and researched, I am under the impression that the power dissipation capacity of resistors are added regardless of whether they are in parallel or in series.
Here are my questions:
1. Can some one confirm that this is 100% accurate? I had read somewhere that this is only true for resistors in parallel and not in series. What do you think? (Please confirm if your answer is fact or theory)
2. If this is accurate, then does it make a difference if the resistors are of different values and have different capacities? Or is this only the case if you are using identical (same resistance) resistors?
For example:
I need to use a 100 ohm 15W resistor. Can I use the following 2 resistors in parallel?
-1pc 100 ohm 1/2W
-1pc 100K ohm 15W
3. What makes a resistor inductive and non-inductive?
I hope my questions make sense. Thanks to all for your help.
For example:
-1pc 100 ohm 1/2W
-1pc 100K ohm 15W
