D
D Yuniskis
I rescue a fair number of items without their respective
power supplies, wall warts, bricks, "whatever".
Usually, I run things through a little routine:
- select a mating connector from "goody box"
- program power supply for correct polarity/voltage
(set current limit to something "reasonable" -- useful
if the morons who made the device failed to mark the
polarity of the power connection!)
- see if device works
(if not, toss in recycle bin)
At this point, I have a "mating connector" but little
more than that (the connectors are too damn small to
*label* in any meaningful way).
So, I use a drill index to sort out the ID and a dial
caliper to get the OD. This covers most of the variation
among connectors (though some also have extended barrel
lengths :< )
Is there an *easier* way of doing this? Or, some
(bizarre) rule of thumb? E.g., a correspondent
recently made the comment that US devices tend to have
center positive -- which seems pretty common though I
know I have found devices with outer barrel positive...
unfortunately, I can't attest as to whether those were
"foreign" manufacture (ha! damn near EVERYTHING in
the US is made overseas, so... ;-)
Thx,
--don
lengths :< )
Thx,
--don
