John
I bought a table saw that I want to change to 240v.
As nearly as I can figure, the power cord goes to a Square D pull out switch
(FP222R). From there it goes to a large Reitech momentary contact switch
(EZO-MS), and then to a Potter&Brumfield device of some sort, and then to
the motor. Unfortunately the part number is rubbed off the P&B device, but
it is a coil with some contacts on it, so I presume it is a magnetic switch.
I can make out 120v, so I am guessing it only good for 120v.
A picture of it is at http://www.frontiernet.net/~toller/switch.htm
Is this guess likely correct? How would I go about changing to one capable
of handling 240v?
If someone is familiar with Potter & Brumfield switches, I would be grateful
for your help.
of handling 240v?
for your help.
