potentiometer joystick
Discussion in 'Electronic Components' started by Daniel O'Shea, Mar 29, 2007.
  1. ....any recommendations for where to find a good little single axis
    centre-return spring loaded potentiometer joystick? (as close to full
    range as possible would be preferable - to be fed to an ADC) thanks!
  2. Every traditional radio control transmitter uses joysticks like this. Some
    are available as spares.
    Best Wishes
  3. Si Ballenger
    Si Ballenger Guest
    Cheap gamepad controllers often have analog pots built in that
    might be of use.
    http://www.geeks.com/products.asp?cat=JOY
