menteausente
- Dec 30, 2014
- 1
- Joined
- Dec 30, 2014
- Messages
- 1
Hi I don't have high level electronics knowledge and I need to know a few things, maybe someone could help me. I want to make a replica of a lightsaber and for that...
I need to connect arround 100 leds in paralel to a 3,7v li-ion battery and I want to regulate the amount of light they give with a potentiometer. Now the cuestions are:
1. What resistance I need to lower down the voltage from the battery to 3v so I dont burn the leds? (1 resistance between the battery's possitive and the led chain is enough right?)
2. What is de amount of ohms that the potentiometer's maximum value must have to barely turn off the leds? (because the more resistance, the less light they will give... RIGHT?)
Specs:
Battery: Li-ion 3,7V 2400 mah (DO NOT ASK MORE ABOUT IT, that's everything I know and all batteries I bougth are the same)
LED: Pink LED
-Max. Forward Voltage: 3.0-3.2V
-Max. Forward Current: 20-30mA (x100 LEDs)
-Potentiometer:
Here it becomes confusing, If I'm not wrong, I need a potentiometer that cand handle 6W of power (?) because 3V x (100 x 0.02Ah) = 6W. What I dont know is the amount of Ohms, I've seen 5k, 10k... I don't know, Is that enough?
THANKS FOR YOUR TIME.
Specs:
LED: Pink LED
-Potentiometer:
