Potential divider circuit
Discussion in 'Electronics Homework Help' started by Wild BMW, Jun 17, 2013.
  1. Wild BMW
    Wild BMW
    4
    Jun 17, 2013
    Hi there.
    I am stuck with this question in a past year exam paper and I would like some help.
    I managed to get Base current and emitter current. and that's it, totally stuck after that!
    A potential divider common emitter amplifier circuit is to be designed. the circuit is to operate under the following parameters:
    VCC = 17v
    ICq = 15mA
    Beta DC = 180 NPN silicon transistor
    VBE = 0.7v
    Question 1.
    Draw the circuit diagram for the above. (this one is easy, as I did do it)
    Question 2.
    Using the standard design rules (which must be clearly stated when used), design suitable components values for this circuit midpoint biasing. the resistor values is to be rounded of to the nearest E12 values?
  2. BobK
    7,682
    1,688
    Perhaps we should see what you drew first.
  3. Wild BMW
    Wild BMW
    4
    Jun 17, 2013
    attached diagram
  4. BobK
    7,682
    1,688
    Okay, good.
    Now, can you figure out the collector resistor based on information given?
  5. Wild BMW
    Wild BMW
    4
    Jun 17, 2013
    Nope. The formula has a missing value which is Vc
  6. Wild BMW
    Wild BMW
    4
    Jun 17, 2013
    Rc = (Vcc - Vc)/Ic
