POT Cores or Toroidal Core inductors.
Discussion in 'Electronic Design' started by Guest, Mar 7, 2007.
  1. Guest
    Guest Guest
    Hi Group:
    I have a project coming up that's going to require some inductors. (an audio
    project)
    the value is 4 henrys with a DCR of 250 ohms. No DC required in the winding.
    The winding will be tapped for 3 different values along the 4 Henry winding.
    I have access to a winder that can do the bobbin style but, to wind the
    toroidal
    cores I will have to purchase a USED machine and learn to use it. My
    question is,
    Can I realize the same QUALITY inductor in a POT core as a toroid?
    I've just started my web research on this subject and haven't found anything
    yet.
    I know for a fact that the bobbin wound for pot cores will be easier to
    handle with the taps.
    I can't use EI cores because of space and shielding issues.
    Any recommendations appreciated.
    RonL
  2. Joerg
    Joerg Guest
    I don't see why not. The question is whether it'll stay that way after
    the unit got banged around a bit. Pot cores are by nature not as tough
    when it comes to mechanical shock.
  3. amdx
    amdx Guest
    Just for fun....How many turns would you be putting on that toroid?
    Mike
  4. Phil Allison
    Phil Allison Guest
    "amdx"
    ....... Phil
  5. ehsjr
    ehsjr Guest
    You are a wicked man! :)
    Ed
  6. Fred Bartoli
    Fred Bartoli Guest
    amdx a écrit :
    Depending on the purpose, it can be easy enough.
    http://metglas.com/downloads/2714a.pdf
  7. John  Larkin
    John Larkin Guest
    Why does an audio project need inductors?
    John
  8. Guest
    Four henrys, at that.
    Toob ckt maybe?
    Mark L. Fergerson
  9. Phil Allison
    Phil Allison Guest
