L
logjam
I have a project where the input of an RS-485 receiver can have
voltage on it before the main power supply comes on.
My project has worked well in the past when my cable's bus voltage was
12v and I used some 12v to 5vDC Astrodyne DC-DC converters.
I am now using a cable bus voltage of 48vDC and some MeanWell DC-DC
converters.
I have experienced strange part failures since switching over to the
48vDC supplies. I think the source of the problem may either be
latchup or the regulated output of the DC-DC converter rising too
slowly. It takes about 200us to go from 0v to 6v and within 50us has
settled to 5v. None of the parts should be damaged from 6v, even
continuously. The parts rarely survive 5-10 power cycles.
I have two signals, one that is about 50% duty cycle at 1MHz, and the
other that is "on" for about 2us and "off" for about 5ms. So far I
have not experienced a problem with the RS-485 receiver connected to
the 2us/5ms signal, just the 1MHz signal. The duty of the signal
shouldn't matter with RS-485, right? Considering A will be what B is
not...
The part failure seems to be where one of the RS-485 inputs either
sinks or sources current into the transmission line. With one part I
observed a 10 ohm resistance from an input pin to ground. This part
does seem to still have some functionality since if both inputs of the
receiver have the same signal the "R" output of the receiver will
mirror its inputs, however there is still current being either sinked
or sourced depending on the specific chip and how it decided to die, I
guess...
The RS-485 devices that I have observed this with are the 75ALS180 and
the MAX3467. Neither are specifically "Hot Swappable".
From reading the Maxim IC data sheet
http://datasheets.maxim-ic.com/en/ds/MAX3465-MAX3469.pdf
I don't understand what makes the MAX3467 not hot swappable and the
3468 hot swappable. As far as I can tell, the feature only makes sure
the transmit stage doesn't activate during processor initialization.
This isn't my concern since I only receive a signal.
I've read about solutions to protect the ICs against latchup. One of
them involved series resistors. I may try to place 10k resistors in
series with the A+B signals after the termination resistor. I can't
imagine that these devices should behave like this, latchup shouldn't
occur on a device like this from the differential input pair.
Can anyone suggest what may be causing my problems?.Which one of these
ideas should I use? Pull up/down resistors? The RS-485 standard
already allows for voltages above VCC and below GND, so if I'm not
crazy I shouldn't be having issues with these parts! The only part I
have left with enough quantity to work with is the LTC485.
Sorry for the long unorganized message. Its been a very long day!
I'll be working on this project all weekend...
Grant
converters.
not...
guess...
Grant
