Possible High LED current with long life time
P
Pubs
I have a application where my LED currents are switched as in a
matrix. My current LED on time is 60 us and off time is 15240 us. The
intensity is problem thus I pump a higher current in that 60 us
(applied potential is arround 9V in that period of time ) and that
gives the required intensity. LED doee not heat up since LED current
duty cyle is extreamly small (rms current is also very small too). Is
this method will reduce the LED life time ?.
Could some one refer some articles on LED life time dependability with
current.
Thank you.
Pubs
W
WJLServo
current.
Thank you.
Pubs
LED die shouldn't mind the high peak currents, as long as thermals are
within bounds. Where you will see some lifetime degradation is in the
bonds between the die's bonding pads and the bond wires. The
phenomenon you want to research is referred to as "electro-migration."
W Letendre
S
Spehro Pefhany
current.
Thank you.
Pubs
Wow. I don't like to go much beyond 8:1 to 10:1. You're doing 250+:1.
I don't think you'll get away with it unless the peak current is not
much more than 5-10x the allowable DC current (meaning the LEDs will
be relatively dim).
Best regards,
Spehro Pefhany
P
Pubs
be relatively dim).
Best regards,
Spehro Pefhany
"it's the network..."                          "The Journey is the reward"
[email protected]             Info for manufacturers:http://www.trexon.com
Embedded software/hardware/analog  Info for designers:  http://www.speff.com- Hide quoted text -
- Show quoted text -
My design works prefectly. IT gives almost like a continoues current
because that current pulse is repeatedly applied. My concerened was
with the life time.
Pubudu
P
Pubs
W Letendre
Hi Letendre,
Thank you very much for your advice.
Pubs
S
Spehro Pefhany
with the life time.
Yes, yes, I know, 'prefectly'. So what does the LED data sheet say
about the conditions you are subjecting it to? For example, here is a
data sheet that specifies maximum PEAK current ("Limits of Safe
Operation") at 25°C of 150mA (only 5 x the maximum DC current) for
pulses of < 10 *microseconds*).
http://www.lumex.com/pdf/SSL-LX5063ID.pdf
It should be derated above 25°C, obviously.
Best regards,
Spehro Pefhany
P
Pubs
Best regards,
Spehro Pefhany
Thank you very much for your help.
P
Pubs
Best regards,
Spehro Pefhany
So the peak current is 150 mA at less than 10 us pulses for this LED
type. Anyway my drivers provide arround 90 mA per LED. I think I am in
the safe region.
P
Pubs
the safe region.- Hide quoted text -
My LED data sheet is shown below.
http://www.jameco.com/Jameco/Products/ProdDS/183222.pdf
According to it, peak current is 500 mA for pulses less than 50 ms. I
am well withing the region.
Thank you for your help.
Pubs
F
Fred Bloggs
current.
Is this a bargraph?
John Devereux
For pulses less than *1* ms, not 50.
Actually, the datasheet is strange. It gives a max DC current of 20mA,
but a max pulse of 500mA at 1/20 duty. Which is a *25* mA average, and
probably much more than that in terms of effective heating.
And is has a "continuous forward current" of "100mW"!
E
ehsjr
According to it, peak current is 500 mA for pulses less than 50 ms. I ^^
Pubs
50 us, not 50 ms, but you are still ok in my opinion
at 60 us with such a low duty cycle (1/255) and 90 mA.
Trouble is, 1/255 (60/15300) seems wrong.
Anyway, your question was about LED lifetime. The paper
at this url may help:
http://www.lrc.rpi.edu/programs/solidstate/pdf/ProjectingUsefulLife.pdf
Ed
S
Spehro Pefhany
Very impressive part, Jameco must have access to some very high
technology suppliers. Compare a similar Avago part:
http://www.avagotech.com/assets/downloadDocument.do?id=2579
Applications
• Commercial outdoor signs
• Automotive interior lights
• Front panel indicators
• Front panel backlighting
Max DC current is 30mA (derate above 50°C) rather than 20mA (?)
Peak current is only 100mA vs 500mA for the Jameco thing.
Max Pd is 111mW vs. 100mW for the Jameco wonder.
Of course it could just be a sloppy translation and layout from a
sloppy Chinese data sheet from a Guangzhou back-alley assembly outfit
that hardly knows what they are doing, but that's just conjecture.
Best regards,
Spehro Pefhany
R
RHRRC
The whole thing is strange - maybe "pub' writes his own datasheets for
leds as the other data offered makes just about as much sense.
With a 1in 255 ratio and 90mA led current the average led current is
only 353uA yet the stated led voltage for this current is 9V!!
(unless it is meant that the average led current is 90mA whence the
led 'on' current is almost 23Amps)
Clearly the fellow has no idea what he is doing else he would not have
chosen such a ridiculous ratio to start with
P
Pubs
chosen such a ridiculous ratio to start with- Hide quoted text -
My current driver can handle upto 100 mA Max (typically 90 mA) with
the duty cycle I mentioned above. Data sheet is strange to me
too ..... but I am in the safe region according to my duty cycle. I
did not check my current pulses since my instruements giving some
problems at this tiny duty cycle. But what I observe is that my LEDs
are realy bright and I dont want to go beyond 9 V at all. My problem
is with the life time. I working on measuring the current pulses.
My design is a LED matrix with 48 rows and 254 columns. I am using
column scanning instead of row scanning. The way I designed it, it is
much cheaper than using row scanning and also less over head for the
uP.
Can some one tell me how do I theoretically calculate the average
current in a such system ?
S
Spehro Pefhany
So you're not limiting the current, just hitting them with 9V? In that
case, think you'd probably getting around 250mA peak current, which
would be more like 5mA average, which would be fairly bright with a
modern LED (you can compare with a DC current and see). The color may
also shift substantially with such abuse.
uP.
Since you aim to have 12,000+ blue LEDs, it will be a bummer if/when
you lose a whole bunch of them.
Multiply the theoretical *average* current per "on" LED times the
number of remaining LEDs which should be on.
Best regards,
Spehro Pefhany
F
Fred Bloggs
MCD lists an Albuquerque, New Mexico address:
http://www.mcdelectronics.com , just another site sparse on technical
information.
It appears the signage silicon market is dominated by start-ups.
Macroblock seems to have a global presence and a product line that
pretty much covers everything:
http://www.mblock.com.tw , very impressive stuff, the big semis are just
plagiarizers by comparison.
From his responses, it is apparent the OP's question is not worthy of
consideration, let him take his confusion to the Basic ng...
P
Pubs
Best regards,
Spehro Pefhany
I dont just apply 9V directly. It has a constant current driver. So it
can not have 250 mA peak currents in anyway. max is 100 mA. Design has
a safety circuit which cuts power to LEDs in case "on" time chages by
+/- 5 us.
Thank for the information. My deisng is continouesly running for
couple of month till now without seeing any intensity changes so far.
Thanks for your unformation.
Pubs
D
Don Klipstein
I would like to add that LED datasheets tend to be conservative in terms
of short high current pulses.
At your own risk, you must do "sufficient reliability testing", but I
give good odds of success with situations that the datasheet does not say
is good.
Slight caution - the LED may have a design change not reflected in the
datasheet and such design change could reduce ability to survive
conditions that the datasheet never supported. Those who abuse LEDs are
"on their own", although so far I have yet to blow an LED with hours of
low-duty-cycle pulsing with peak current that according to the datasheet
"should blow the LEDs sky-high" (my words).
I would like to add:
Look at the datasheet for both peak current and maximum pulse duration
and also duty cycle.
So far, I have yet to blow an LED with higher peak current as long as
pulse duration is reduced in inverse-square relation to increase in peak
current according to the datasheet, the average power dissipation does not
exceed what the datasheet supports as allowable (even with higher voltage
drop at higher current), and the RMS current does not exceed what is known
safe.
As in: For most LEDs rated 30 mA max continuous, 100 mA max peak at 10%
duty cycle and for 10 milliseconds on-time (cycle period 100 milliseconds):
RMS current tends to be allowed to be up to 32 mA or so according to the
datasheet, though not documented when peak current gets past 100 mA.
I would extrapolate to pulse duration at current past 100 mA being 10
milliseconds times square of ratio of 100 mA to actual pulse current, and
allowable duty cycle 10% times is square of ratio of 100 mA to actual
pulse current.
So far, I have yet to bloe LEDs with such conditions with pulsing to an
amp or so. However, I do warn that doing anything outside the datasheet's
box is at your own risk!
One more thing - LEDs are nonlinear. Most white, blue, and
non-yellowish-green ones are more efficient at lower peak currents!
Same story at least with "low current red" - as in most red ones of a
30-plus-year-old chemistry but having nominal peak wavelength of 690, 697
or 700 nm (believe me, their bandwidth is on the high side for
phosphorless LEDs).
Most high brightness and high efficiency ones other than the above tend
to have efficiency maximized when peak current is in or near the range of
from half of maximum rated continuous current to double maximum rated
continuous current.
One more thing with pulsing LEDs: Watch for higher voltage drop, and do
not exceed maximum rated power dissipation (I find that is usually easy to
obey with lower average current when peak current is high and a maximum
RMS current is obeyed).
RMS is not 1.11 times average for most pulsed waveforms - for
rectangular pulses, RMS is peak times square root of duty ratio. For
example, 1 amp at duty ratio of .1% or 1/1,000 has RMS current of 31.6 mA.
- Don Klipstein ([email protected])
R
RHRRC
+/- 5 us.
Pubs- Hide quoted text -
If your led current is 100mA and the duty ratio is 1 in 255 the
average led current is 392uA.
Allowing nothing for the reduction in efficacy due to the high
current, the observed 'brightness' of the led will be the same as if
it was powered with a constant current of 392uA.
Quite clearly this would not result in the 'bright' leds you report
and one is led to conclude that your currents are much higher than you
state.
