Davewalker5
- Sep 20, 2014
- 125
- Joined
- Sep 20, 2014
- Messages
- 125
I don't understand what Q21 , 2N6315 on the Voutput pin#6 is going for the Positive +15 volts supply supply
What is VR2, Q19, Q20 doing for the Negative supply on Voutput pin#6 ? what kind of circuit is V2, Q19, Q20? and why doesn't the positive regulator not have a VR2 or Q19, Q20 only the negative regulator?
I also don't understand why they would connect the Positives Regulators CS output as the Input of the Negative supplys regulator? any reason why? the CS is the current sensing , so they are using the current sensing input voltage as the negative regulators input
What technique is this called?
