K
[email protected]
I've started my senior project and I'm running into some questions..
What the project is, is a modular device that will need to record the
x,y,z displacement from its original location and its orientation
(tilt, yaw and roll degrees). I've been searching around and it looks
like the orientation can be done with a mixture of gyro sensors and
analog output compasses (i think it's called a dinsmore compass). But
anyways, what's boggling me is a solution to calcluate the current
position. I've read about the accelerometers and it sounds like
there's a lot of error involved. And our spec is to have the device
measuring for 30mins, at a sample rate of ~30Hz, so I am assuming there
can be a lot of error introduced and propagated through time. And I
thought of GPS before we got some specs, but due to their slow reading
rate that is out of the question. Does anyone know of a good way to
measure position other than using accelerometers? or is there a way to
perhaps use a three axis accelerometer without much errors, or
filtering out errors? Thanks!
