Portable power pack help
Discussion in 'General Electronics Discussion' started by Frankie Bateman, Jul 19, 2017.
  1. Frankie Bateman
    Frankie Bateman
    6
    Jul 19, 2017
    Hi people. I'm new and also fairly new to electronics thanks for reading.
    I'm building a portable power pack for myself with a 12v 20ah li ion battery inside I have the following connected.
    12v cigarette port
    12v dual usb point
    12v aux for 12v led strip light
    12v 4 channel wireless switch receiver
    12v volt meter
    5 x 20 slow blow 5a fuse
    Anyhow I'm having a couple of issues. When I plug the charger in it shorts the whole thing so I have to remove the fuse and replace put it in? Also if one of the ports is switched on ie led light and I plug it in it shorts again. Very confusing for me is there anything that can be done to prevent this happening?
    Also another thing is the battery can only do about 3 full phone charges! I've calculated it to do about 20 hours of phone charging or 9 hours of a portable tv and about 40 hours of the led light but it clearly didn't do any of this what could be the problem here?
  2. davenn
    davenn Moderator
    13,833
    1,950
    ok
    you understand you cannot just plug the Li Ion batteries straight across a 12V source to charge them ?
    they need a very specific charging system
  3. Frankie Bateman
    Frankie Bateman
    6
    Jul 19, 2017
    They are designed like this with a built in Over-charge/discharge protection. I'm using the charger that came with it?
  4. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    How about a wiring diagram for the whole unit?
