My 2 cents on a portable AC:
1) Get a model with two hoses - the two hose models use outside air to
cool the condenser and will be more effecient. You will not be
sucking the cooled air out of the room to blow it outside - this is
what the models with one hose do (the condenser air comes from
somewhere.
2) Be prepared to have a real drain (ie hose going somewhere) on the
unit unless you want to be emptying condensate all the time. They
seem to be able to blow some condensate out the air hose, but unless
you are in a dry area you will probably get more condensate than what
it can evaporate out the air hose. (If you want to pump water out the
window you will probably need a condensate pump and some
3) They are for the most part pretty quiet. It seems most of the
noise is what you can hear through the thin walls of the air hoses
leading to the window (these hoses connect to the area the condenser
fan and compressor live in - most of the noise is in there).
I personally have had a PAD-121 running every night for 3 years
without any issues. That model is no longer available, but the
successor is:
http://www.heatcontroller.com/series.php?prod=ca&sid=15&c=17
