Pool chlorinator, Pool Store International, Q Diamond 1200
Discussion in 'Hobby Electronics' started by Franc Zabkar, Aug 15, 2004.
  1. Franc Zabkar
    Franc Zabkar Guest
    I have a salt water chlorinator, model Q-Diamond 1200, manufactured by
    Pool Store International. It has a faulty controller module which I
    haven't been able to remove from the front panel. It appears to
    consist of two halves, one on each side of the front panel. There are
    no screws, just eight dimples in the plastic fascia (4 at the front, 4
    at the rear) which suggest some kind of tamper proof snap lock
    fasteners may be used. I've decided to drill these out, but before I
    do so, does anyone have any experience with these units?
    BTW, I've already contacted the manufacturer, but they were of no help
    at all.
    - Franc Zabkar
  2. Franc Zabkar
    Franc Zabkar Guest
    OK, I drilled out the dimples and the two halves of the controller
    separated as expected. Unfortunately the electronics are potted in
    epoxy. :-(
    - Franc Zabkar
  3. tb
    tb Guest
    You may be able to get the part from www.directpoolsupplies.com.au
