Polymer LED life at high temperature
Discussion in 'Electronic Design' started by Spehro Pefhany, Sep 10, 2004.
  1. Anyone got any solid information on lifespan of these devices at
    temperatures in the 40-50°C range?
    Best regards,
    Spehro Pefhany
  2. Fred Bloggs
    Fred Bloggs Guest
    This article from Materials Today has a ton of references some of which
    go into degradation and failure effects. The main thing would be to
    determine the failure acceleration factor function for temperature, and
    it will come down to the manufacturer quality control.
    http://www.depeca.uah.es/wwwnueva/docencia/ING-ECA/tec-disp/art4.pdf
  3. Thanks. Wow, there *are* a lot of references there. There are two
    factors in the quality control- the materials themselves (which should
    be very consistent) and their application (eg. by spinning) and the
    design of the moisture barriers etc (which are different companies,
    and probably much less dependable). The lifetimes (to 50%) of some
    these things are in the 10K hours range even at 25°C..
    Best regards,
    Spehro Pefhany
  4. Phil Hobbs
    Phil Hobbs Guest
    Yeah, there are also some very unusual materials used in OLEDs, e.g. calcium
    metal.
    Cheers,
    Phil Hobbs
