Polaroid's flat OEM battery, from the SX-70 filmpak
Discussion in 'Electronic Design' started by Winfield Hill, Mar 20, 2007.
  1. I'm trying to find some engineering info on Polaroid's flat battery,
    you know, the battery they designed for the SX-70 camera filmpak,
    and then sold as an inexpensive flat OEM battery. Didn't they call
    it the PolaVolt? Maybe not, because there's nothing on the web by
    that name (except for some cyclic voltammetry stuff). Does anyone
    remember, or perhaps someone has a datasheet in their dusty cabinets?
  2. mpm
    mpm Guest
    I think it was called the "PolaPulse". (?)
    -mpm
  3. Wow, that's a fast respone! Yes, that's it, and instantly got
    me a datasheet for their P100, www.photobattery.com/P100.pdf
  4. I thought it was called PolaPulse.
    - Don Klipstein ()
  5. Robert Baer
    Robert Baer Guest
    Tradename *on* the battery packs from filmpacks for their OneStep
    Flash camera: "Polaroid PolaPulse(TM) Battery".
    Size: 3.50 X 4.25 x 1.70 (appx); nominal voltage 6.0V (after all of
    these years, mine are around 5.8V).
    As i remember it, they use the Leclanche design.
    Approximate size of the active area is 2.0 X 1.5; if you want i could
    Snail one to you.
  6. Robert Baer
    Robert Baer Guest
    That PDF designates a PolaPulse(TM) that is different in
    configuration than the ones i mentioned (and have).
    Same technology and basic design.
  7. Rich Grise
    Rich Grise Guest
    Are these dims in inches? I thought they were about 1/4" thick; even
    the whole film pack wasn't an inch and 3/4; more like 0.7 for the whole
    film pack, IIRC.
    How about posting a pic somewhere?
    Rich
  8. Gary Tait
    Gary Tait Guest
    IME, they were unlabelled. The one in the camea packs were of a carbon-
    zinc leclanche design. I have a pocket flashlight here someplace with
    one. I have used them to power a portable radio, and in fact Polaroid
    had a radio you could plug whole spent film packs into, to power the
    radio.
  9. Robert Baer
    Robert Baer Guest
    Actual measurements; yes, inches.
    From the 600 Plus film packs; obviously different than the PolaPack 100.
    Maybe i could Snail one to you.
  10. Robert Baer
    Robert Baer Guest
    The ones i have (from Polaroid 600 Plus packs) are all labelled, i
    wrote what i read - if theer had been no labelling or designations, i
    would not have responded.
  11. Rich Grise
    Rich Grise Guest
    Oh, that won't be necessary. :) Apparently I've only seen the model 100;
    and there's no reason to think you're making anything up. :)
    Thanks!
    Rich
