C
CWatters
I'm having problems with this annoyingly simple P-Chan FET circuit ....
http://users.pandora.be/colin.watters/new_timer/polarity_protect.jpg
With the correct input voltage it seems to work fine, but when the input
polarity is reversed the FET doesn't turn off for some reason.
With the input polarity _reversed_ the FET terminal voltages are:
Drain = -24V
Source = -24V
Gate = -12V
So the gate is at +12V wrt the Drain/Source. Since Vgs(th) for this FET is
about -2 volts it really should be OFF.
At first I thought I was measuring leakage currents on the output so I
loaded the output with a few Ohms and they got hot - so the FET really is
conducting.
With power removed the FET switches off.
I replaced the FET with another the same and got the same result.
The body diode is the right way around.
All the zenners are for static protection. With reverse input polarity (and
the FET conducting when it should be off) D3 is toast and has been removed
until I can get the FET to turn off.
The potential divider on the gate is to reduce Vgs to 12V. Max Vgs for the
part is +/- 20V.
Any ideas?
Colin
Drain = -24V
Source = -24V
Gate = -12V
conducting.
part is +/- 20V.
Any ideas?
Colin
