Pocket Oscilloscopes
Discussion in 'Electronic Design' started by [email protected], Mar 7, 2007.
  1. Guest
    Anybody producing a pocket scope besides velleman?
    PPS10 is attractive, but 64x128 is a drag.
    I frequently need to troubleshoot audio sigals in the field
    desired bandwidth dc to 2 mhz.
    I'd settle for dc to 500khz.
    No, usb need not apply, dont always want to drag the laptop out.
    Steve roberts
  2. DaveC
    DaveC Guest
    sez:
    IMHO, the "pocket" scopes aren't very reliable. Had a Fluke one that started
    to have its display draw black lines permanently on it.
    Don't know anything about this, but saw this page today:
    <http://www.saelig.com/miva/merchant.mvc?Screen=PROD&Product_Code=PSSA002&Cate
    gory_Code=>
    Give us feedback, whatever you decide to buy...
  3. Hawker
    Hawker Guest
    At the last place I worked I needed a small portable battery powered
    scope often. I tried a few of the VOM type scopes and gave up as they
    all were less than I wanted.
    I ended up getting a Tektronics THS series. I think it was a THS730A but
    you might want to check the THS720 or THS710 as it is only 100Mhz for
    the 720 and 60 for the 710.
    I bit pricey I know, but nicer than a VOM style by a long shot.
    http://cgi.ebay.com/TEKTRONIX-THS71...yZ104247QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    Hawker
  4. maxfoo
    maxfoo Guest
    How big is your pocket? Are you planning to shoplift a scope?
  5. Jim Yanik
    Jim Yanik Guest
    Support for those THS7xx scopes is going to be a problem.
    Sadly,TEK is no longer the company that it used to be in regards to service
    and support.
