pocket door
Discussion in 'Security Alarms' started by Spudz, Feb 18, 2008.
  1. Spudz
    Spudz Guest
    Gotta contact a pocket door. never tried to contact one of these before.
    wires coming in from below with crawl access or can still get wire anywhere
    for next few days. any tips greatly appreciated. TIA
  2. Frank Olson
    Frank Olson Guest
    Got a picture?? On most wooden pocket doors, you can put the contact
    (3/8") in the frame just under the latch (closer to the floor if you're
    coming up from there), then put a concealed magnet in the door (abutting
    the contact).
  3. Piece of cake, friend. About 2" above the floor, drill a 3/8" hole into the
    door frame, parallel to the floor. Slip just the tip of a 16" long by 1/4"
    diameter bit into the hole. Drill down to the basement at a 60º angle off the
    floor and slightly sideways so the drill takes a compound angle. That way if
    you happen to be above a joist the bit will come out the side instead of
    having to bore all the way through. Use any press-fit, 3/8" contact. The
    feeler bit will cut a small notch at the top of the 3/8" hole. After
    inserting the contact, touch up with colored wood putty.
    Basically, you're doing the same thing you might do for a wood-framed slider.
    Enjoy.
    Regards,
    Robert L Bass
    Bass Home Electronics
    4883 Fallcrest Circle
    Sarasota · Florida · 34233
    http://www.bassburglaralarms.com
    Sales & Tech Support 941-925-8650
    Customer Service 941-232-0791
    Fax 941-870-3252
  4. JoeRaisin
    JoeRaisin Guest
    Single door or double door?
  5. Spudz
    Spudz Guest
    single
  6. JoeRaisin
    JoeRaisin Guest
    Then the others have already given you the best advice.
  7. Crash Gordon
    Crash Gordon Guest
    hopefully that pocket door has a secure latching mech. ...the one's I've
    seen the past 15 years all had crappy locks.
    **Crash Gordon**
    | Spudz wrote:
    before.
    | >>> anywhere for next few days. any tips greatly appreciated. TIA
    | > single
  8. Frank Olson
    Frank Olson Guest
    Pocket doors (in Canada) are "sloppy" on purpose. We have to make them
    that way to make up for the way changing weather conditions affect the
    Igloo's interior.
