Reposting in order to finish the message...
mc said:
Well, for starters, it is *not* electrically charged. The electrons *do*
match the protons, making the whole thing neutral, just as with most of
the other matter in the world.
What differs is whether there's *room* for the electrons in the crystal
structure.
Around every silicon atom, there's room for 4 electrons in the crystal
structure of silicon. These are the 4 valence electrons (outermost shell
electrons) of silicon.
Put in an atom with only 3 electrons in its outer shell, and there's
*still* room for 4. There is no net electrical charge, but there is a
"hole" which an electron could move into. (Put in a lot of these and
you get P-type silicon.)
Put in an atom with 5 electrons in its outer shell, and there's an
electron left over. In terms of electrical charge, it needs to stay there
(to balance the charge of the protons in the nucleus), but the crystal
structure doesn't accommodate it. It hangs around without fitting tightly
into a specific position. That is, it becomes a conduction electron.
(Put in a lot of these and you get N-type silicon.)
Conduction electrons make it easy for matter to conduct electricity
because they're free to move. Holes also make it easy for matter to
conduct electricity because a hole can move; that is, an electron from the
next atom can fall into it, leaving a hole at the next atom instead of
where it started out.
Now then. In a diode, which is a single P-N junction,
you apply a voltage to pull the holes (in the P-type
material) toward the conduction electrons (in the N-type material). In the
middle of the diode, they meet and join, and conduction occurs. If you
apply the voltage the opposite way, the holes and conduction electrons
never meet, and no current flows.
Transistors are more complicated. One key concept is that if you can
somehow bring a lot of electrons into a piece of P-type material, it starts
to act like N-type. That is, it has conduction electrons because you
brought them in by conduction, not because they came in with the atoms.
Well... Consider a three-layer stack, N, P, N. Use the first two (N, P) as
a diode and make it conduct. That brings plenty of electrons into the P
layer.
While this is going on, also apply a positive voltage to the third electrode
(N). That ought not to make it conduct, because the second P N junction
would have voltage on it in the reverse direction. But what actually
happens is that when you make the first (N P) junction conduct, it's like
opening a floodgate. Once those electrons get into the central P region,
they go right on through. (The second P N junction doesn't stop them
because the P layer is full of electrons and no longer acting like P
material, no longer relying on holes to do its conducting.) You get many
more electrons that you ask for; that is, the small current through the
first junction is amplified. That's how an NPN transistor works.
I predict that someone will jump on me and say, "No, it's not that way at
all, it can only be described mathematically." To which I reply: "Just
because *you* can only quote formulas doesn't mean the physical phenomenon
isn't real."
