PNP as switch with different emitter voltage
Discussion in 'Electronic Design' started by Jon Danniken, Jan 16, 2011.
  1. Jon Danniken
    Jon Danniken Guest
    Hi, I am trying to take advantage of an extra flip/flop output in an
    existing circuit. The driving signal is either 0V or +5V, but the emitter
    voltage (to drive the switched load) is +18V.
    This is the circuit I am planning to use:
    +18V
    Rb |
    ___ |/
    On=0V ---|___|-----| PNP
    Off=5V |<
    | | Load (15mA)
    GND
    I am going to try getting the base resistor to be such at the transistor is
    off when the IC is at 5 VDC, and on when the IC is at 0 volts.
    Besides fiddling with the base resistor, is there a different topology, or
    modification I can make to the existing one to make this work better?
    I do realize that putting an NPN transistor off of the IC's output would
    solve this nicely, but space is at a premium, and I would like to do this
    with just the one transistor.
    Any ideas?
    Jon
  2. Pimpom
    Pimpom Guest
    Insert a 15-volt zener diode in series with the base resistor.
    This way, the zener will break down and drive the base only when
    the FF output is in the low state. Depending on the gain of the
    transistor, I suggest 1.5-3.3k base resistor. It's also a good
    idea to place a resistor across the b-e junction to bleed off any
    leakage current through the zener diode. Something like 10k
    should be OK.
  3. Sjouke Burry
    Sjouke Burry Guest
    Very unstable, and the slightest error will blow the circuit
    attached to the output.
    Connect to a save voltage instead, like 5 or 3.3 V depending
    on the type of destination.
    If you insist on this config. at least put a bleeder resistor
    between base and emitor.
    That makes it simple to reach an off-state,13 v on rb and
    r-bleed produce less then .7 volt on the base-emitor,
    and when switching, 18 v on them and Vbe gets a bit higher.
    Example:13 volt:Rb 12k,rbe 560 ohm, ~.5 volt, so off.
    18 volt: , ~.75 volt so on(sort of).
    But it is a lousy solution anyway.
    The way you did it, the transistor will be on all the time,
    never giving 0 volt out.
    So what output do you need?
    And does it HAVE to be a pnp transistor?
  4. Guest
    Not going to work. The base-emitter is always reverse biased and the
    collector-base is always conducting (actually the transistor will operate with
    reverse beta but won't switch). If you reverse the emitter and collector with
    it's emitter hooked to +5V and the load in the collector, it should work, but
    you're only going to get a ~5V swing. You will get ~15mA if the load is
    333ohms.
    Not going to happen. There will always be current flowing in the
    collector-base diode. Reverse beta is really crappy so it's not going to
    switch.
    Reverse the emitter and collector and tie the emitter to +5V.
  5. Sylvia Else
    Sylvia Else Guest
    I assume you've put the transistor the wrong way up by mistake.
    If you attach the emitter to +18V and the collector to the load, and
    then stick a resistor between the base and +18V, then by a suitable
    choice of resistor values, you can make the transistor switch.
    Except that I suspect that your inputs are not really 0 and +5. In
    particular, your input may not be willing to sink current at 5 volts.
    Depends on the IC. A diode to 5 volts could cure that (but watch out
    that you don't ask the PS to sink current in the process), but it will
    still be pulling the IC output a bit above 5, and you'd have to check
    that that's OK.
    However with such an arrangement you also have the problem of whether
    you can actually pull enough current from the base to switch the
    transistor with a 15ma load, which is going to depend on the actual
    properties of your IC and the beta of your transistor.
    You'd be driving the transitor into saturation, which means there'll be
    a turn-off delay. What switching rate are you dealing with?
    Sylvia.
  6. Sylvia Else
    Sylvia Else Guest
    What's on the left of Vin is never asked to source current, but
    presumably there's no doubt it can sink current when it's driven low.
    The doubt would be as to its behaviour when driven high - usually it
    would expect to source current in this state, so will it still sink it?
    But you're assuming that it will, so...
    Consider Veb when the transistor is on to be 0.6V (Veb because it's PNP).
    Suppose we want to switch when Vin traverses 2.5V.
    Then:
    0.6 = (18 - 2.5) * R2/(R1 + R2).
    0.6R1 + 0.6R2 = 15.5R2
    0.6R1 = 14.9R2
    R1 = approx 24 * R2
    Vb would only rise to 17.5 (Veb = 0.5) volts when Vin is 5v, but that
    should be enough to turn the transistor off.
    The main issue I see with this arrangement is whether it is possible to
    sink enough base current to saturate the transistor given the value of
    load, which depends on the thing IC driving Vin, and the transitor beta,
    but I said that.
    If it's an ideal IC, and can sink an infinite amount of current in both
    states, then it's just a matter of choosing the resistor values with
    knowledge of the worst case beta.
    It would be more difficult if the OP wanted the opposite switching
    behaviour.
    Sylvia.
  7. Sylvia Else
    Sylvia Else Guest
    I would add that I wouldn't want to use this approach in a circuit
    intended for mass production. A combination of adverse IC output
    characteristic, resistor value and transistor variation would mean it
    was asking for trouble.
    But as a one off...?
    Sylvia
  8. Jamie
    Jamie Guest
    I am sure by now, most have seen the problem.
    Your transistor is backwards.
    jamie
  9. Pimpom
    Pimpom Guest
    Yeah. I actually started out meaning to add "if there's room",
    but forgot about it.
    I used the zener technique in a design last year. The difference
    is that the digital chip and the PNP transistor used the same 12V
    supply. It would have worked without the zener if I'd kept to my
    initial design, but I added a load between the chip output and
    ground. This pulled the output below Vdd in the HI state, low
    enough to turn the PNP tr on. Inserting a 5.6V zener and changing
    the base resistor value solved the problem.
  10. Jon Danniken
    Jon Danniken Guest
    Thanks Pimpom, I hadn't thought of that. I'll pick up a zener tomorrow and
    play around with that.
    Jon
  11. Jon Danniken
    Jon Danniken Guest
    Indeed I did, I went with what the ascii conversion software gave me instead
    of flipping and mirroring it. My apologies for not noticing that.
    It's coming off of a 4013 flip flop, and I did actually measure the outputs
    to be +5 or 0. The other output from the IC is inverted, and in use
    (driving an NPN), hence my desire to use the PNP on the other output.
    Measured in seconds. The load is a piezo beeper that goes off until I get
    annoyed enough to go push the reset button.
    Jon
  12. Jon Danniken
    Jon Danniken Guest
    Hi Sjouke, it doesn't have to be a PNP, but the logic of the IC output (5V
    when I want this off, 0V when I want this on) suggested that to me. The
    output is driving a 15mA piezo beeper.
    I'm going to try the suggestion of the zener on the base (and a BE resistor)
    and see where that gets me.
    Jon
  13. Pimpom
    Pimpom Guest
    What's the load on the NPN? Is it similar to or lighter than the
    beeper? If so, the 4013 can drive the two loads from one FF
    output if the transistors have reasonably high gain.
    For example, a BC547B or a 2N3906 can switch two 15 mA loads with
    ~1 mA base current. A 2.2k-3.3k resistor plus the 4013's internal
    output resistance will supply more than enough base current to
    saturate the transistor with a 30mA load. If it's not convenient
    to parallel the two loads and drive them both with the existing
    NPN transistor, you can add the extra NPN and drive it with the
    same FF output via a 3.3-4.7k base resistor. There's no need to
    go to the trouble of using a PNP on the other FF output.
  14. Pimpom
    Pimpom Guest
    You may not even have to do that. See one of my other replies
    about driving two loads with the other FF output. I've driven
    heavier loads reliably at much higher frequencies with a single
    CMOS logic output.
  15. Jon Kirwan
    Jon Kirwan Guest
    The OP says this is on the order of seconds (manual
    shut-off.)
    Assume Q2 nearing saturation sufficiently well with beta=50,
    then the Q2 base current should be about 15mA/50 or 300uA.
    The on/off control needs to be able to sink 300uA, plus a
    little more for R2 (say 10% of 200uA) and Q1 base (likely
    only 2-3uA.) R1 needs to supply that when the on/off control
    is at or near 0V. Assume about 1V for compliances needed by
    Q1's Vbe and the sinking output near 0V... so:
    R1 = (5V-1V)/(300uA+30uA+3uA) = 12k
    R2 = 0.7V / 30uA = near 22k
    Close enough for student work. Could add a speed-up cap
    across R1.
    Jon
  16. Jon Danniken
    Jon Danniken Guest
    Yes, I had thought about piggybacking onto the output already in use, but I
    thought it would be less intrusive to use the other output (there is already
    a trace with an unused solder pad out of it).
    Jon
  17. Jon Danniken
    Jon Danniken Guest
    The problem is that an NPN on this output will give me the opposite from
    what I am after. I am trying to switch on the load from a 0V signal, and
    turn it off with a 5V signal.
    NPN would work if I was trying to switch the load with a 5V signal, but that
    is not what I am doing.
    Jon
  18. Andrew Holme
    Andrew Holme Guest
    You have been given two different ways of connecting the NPN. The
    configuration where the NPN base is at 5V and the emitter is driven by the
    logic output does what you want.
  19. Andrew Holme
    Andrew Holme Guest
    It needs some resistors in there too, to limit the current. Try it in
    LTSpice.
  20. Jon Kirwan
    Jon Kirwan Guest
    meant 'of 300uA'
    Jon
