Jean said:
How is it possible?
An audio power amplifier with a 40v power supply,powering two 8 Ohm
speakers in parallel(Not a BTL load).Whatever it does,the maximum
power it can deliver to the load is VxV/R i.e 40x40/4=400W.Then why is
it written 5000W PMPO on it?
Because marketers are only bound by law if the law can catch up with them.
Never confuse that which is written with the truth.
But if you wish to be hopelessly pollyanna-ish, then here's a
rationalization: "PMPO" stands, presumably, for "peak music power output".
"Music power" is a euphemism for "power that only has to be delivered once
in a rare while" - that is, 500W "music power" is only about 50W average
power. So, if you can deliver 50W average power, then you can fool yourself
into thinking that you can deliver 500W "music power" even though, when the
occasional 500W peak comes along, you can't actually deliver it.
Here's another way of thinking about it: what THD is that 500W specced at?
If in a given music test signal only 5% of peaks exceed 50W, and if I clip
5% of the peaks (that is to say, I clip everything over 50W), then I might
still be under a few percent THD. Suppose those peaks are actually 500W.
Then, I can say that I am delivering "500W of music power" at a few percent
THD.
The bottom line here is that there are many, many ways to mislead with power
specifications.
