Can anyone assist with the following please?
Seeking a spring loaded plunger switch ( car door/ fridge door style ) which gives a short signal when cycled. I would use the term " Momentary " but am not sure that this would be correct.
By this I do not mean "Push to make" or "Push to break" but rather, a non latching plunger switch which makes electrical contact only in mid travel. This switch need only have two terminals, though a multi purpose unit would be acceptable provided that it has the desired function.
Any suggestions as to the supply of such a switch would be grately appreciated.
Thank you.
Petel
Thank you.
Petel
