P
Phil Hobbs
Stefan said:Hello,
I am trying to understand how a particular vcxo-based pll works.
When using a spectrum analyzer to probe the oscillator part
of the circuit, I find spurs located at 44 kHz away from the
main frequency (say 200 MHz). These spurs are not present when
there is no input clock to lock on to, i.e. when the vcxo is
freely running; they are there only when the pll is locked
on the incoming clock. The PFD works at 1/4 the vcxo
frequency which is also the input clock frequency. So I cannot
understand where these spurs may be coming from?
Should this be a worry? I could imagine that these spurs
may under some conditions excite some spurious modes of the
crystal itself (unless they are actually exactly that, but they
do not seem to, since the crystals have been characterized beforehand
and there is no spurious mode at 44 kHz from the fundamental?)
Should I add that I have no experience whatsoever with this
sort of things...
Stefan Simion
Guess: you're running this off a switching power supply. When the PFD
is not running, its output is sitting low, and hence sees little or no
power supply noise. The oscillator has an internal supply filter or VR
to prevent its being pulled.
Cheers,
Phil Hobbs
