PLL Programming - Analog Devices
Discussion in 'Electronic Design' started by [email protected], Jul 6, 2005.
  1. Guest
    I'm currently working on a sweepable LO source for a receiver. I am
    using a VCO in a PLL with an ADF4113 phase/frequency synthesizer chip
    available from Analog Devices. I need to sweep the output frequency of
    the VCO in a specific band. I was wondering if anyone has worked with
    these chips (or similar) before. My issue is that I need to calculate
    the best possible value for the "N" divisor given a frequency step size
    of 1.3375MHz and I was wondering if anyone out there has developed an
    algorithm for doing this.
    Thanks for any help you may be able to provide me.
    -Chris
  2. That shouldn't be such a problem. There is a
    divisor dividing the reference down to the
    channel distance aka comparator frequency and
    then there is a divider dividing the output
    frequency down to the channel distance.
    The higher the divisors, the higher the phase noise.
    Rene
  3. ZenSafari
    ZenSafari Guest
    Yes, calculating the divisor is no problem at all. My issue, however,
    is that I need to select the optimal configuration for the divisor
    given that:
    N = (P*B) + A
    I need to automate the calculation of P, B and A in software based on a
    set of desired output frequencies to obtain the correct value for N. I
    got something working yesterday that seems to do the trick, however.
  4. Thomas Magma
    Thomas Magma Guest
    I've done this. I wrote an app to generate all possible combinations between
    two frequencies of interest. It puts the output values into a delimited text
    file so you can import them into Excel and sort them based on frequency or
    comparison frequency or what ever you want. It's written for a Pocket PC.
    Thomas
  5. John Miles
    John Miles Guest
    If you have a choice, you'd normally want to minimize the N factor,
    subject to the N >= P*P-1 constraint inherent in the dual-modulus
    divider logic. The more multiplication the PLL chip has to do, the more
    it will amplify the reference's noise (and its own inherent noise).
    Your step size -- hence your comparison frequency, in a simple single-
    loop PLL -- is 1.3375 MHz. That's a perfectly-reasonable comparison
    frequency for these chips, so N should simply be your output frequency
    divided by 1.3375 MHz.
    P is the factor you'll actually have to choose. You didn't mention your
    minimum output frequency, but let's say it's 1337.50 MHz. If N is 1000,
    you can't use a prescaler value of 64, because 64*63 is 4032, much
    larger than 1000. The next available P modulus is 32, which works (32*
    31=992). Smaller P factors will work, too, as long as the prescaler's
    output to the A/B counters is no higher than 200 MHz.
    You *could* choose N to be some integral fraction of your step size, say
    (output frequency / 1.3375 MHz) * 10. If your comparison frequency were
    much higher than a few MHz, that might be worth considering... but I'd
    say not in this case.
    You can simulate your loop with ADIsimPLL (free download from Analog),
    and take the results to the bank. It's good stuff.
    -- jm
  6. John Miles
    John Miles Guest
    Sorry, I missed some parentheses: should be N >= P*(P-1).
    -- jm
