PLL confusion
Discussion in 'Electronic Basics' started by jim, Nov 12, 2004.
  1. jim
    jim Guest
    I'm trying to learn about PLL circuits and admittedly I'm a newbie and
    therefore confused as usual. Why is the phase detector portion of a
    phase lock loop (analog) called "phase detector" when what it really
    detects is a difference in frequency. That is two waveforms with
    different frequencies cannot have any fixed phase relationship. As I
    understand it putting two identical frequencies that are some fixed
    phase apart will not give any signal out of the phase detector, only
    two different frequencies will give a dc current out. I've obviously
    got something muddled up here ,what is it? thanks jim
  2. Phase and frequency are tightly related. Nevertheless, the output of a phase
    detector is related to the phasedifference of both inputsignals regardless
    what frequencies are used. When both frequencies are not equal (and not
    otherwise related) the output of the phase detector will vary over time. As
    you already know, these variations are used to control a VCO which makes one
    input move to the point that the VCO is locked on the other signal.
    petrus bitbyter
  3. John Larkin
    John Larkin Guest
    If the frequencies are different, the phase is "rolling."
    No, it detects and indicates phase. The result is some DC level if the
    frequencies are truly equal, or a "rolling dc" level (which is
    typically a sine or triangle wave) if they are really different.
    Classic (simple) phase detectors detect phase difference, not
    frequency difference. So if the two input frequencies are, say, 10 Hz
    apart, the pd output is a sine or triangle wave at 10 Hz. If the
    signals are the same frequency but differ in phase (timing) the pd
    will give a corresponding DC out.
    Such a classic pd (a multiplier, diode mixer, xor gate, d-flipflop
    etc) when fed into the oscillator control loop will result in lock
    only if the phase change is relatively slow, which only happens if the
    frequencies are close. If the frequencies are too far apart, the pd
    output is a high-frequency waveform with no dc component that just
    confuses the vco. So a simple pll has a limited "acquisition range",
    even though it may track a wide range *once it gets into lock*.
    There are complex phase detectors that are smart enough to realize
    that they are way out of lock, in which case they force the pd output
    in the right direction until they're close enough to work in true
    phase-detect mode. That solves the acquisition problem.
    If a loop had a true frequency detector, any tiny analog error would
    result in the vco frequency being not exactly the input frequency. But
    a loop with a phase detector has zero longterm frequency error; the
    waveforms are locked.
    John
  4. Peter Lawton
    Peter Lawton Guest
    I'm doubtful if 'phase' is the right word too. the phase difference of two
    non - same frequencies increases over time and never repeats.
    Peter
  5. Active8
    Active8 Guest
    This is not true. A 5 and 10 Hz signal that start off in phase, will
    be in phase after one cycle of the 5 Hz wave, for example.
  6. peterken
    peterken Guest
    Simply stated:
    A pll generates a frequency related to a measured input-frequency
    The relation might be 1-to-1,
    OR,
    if in the feedback circuit a divider is built in the relation will be N-to-1
    (a typical pll-based frequency-multiplier)
    Even if the measured frequency and the generated frequency are say 0.000001%
    un-equal, you WILL get a phase-difference over time between pll-generator
    and input
    The phase detector will detect this difference, and charge/discgharge a
    filter circuit to set the vco of the pll tot the correct "phase"
    Result : Since phase and frequency are so tightly related, the pll will
    adjust not only phase, but also frequency
  7. For specific cases:)
    In general cases the phase between two signals is not definable at all.
    Kevin Aylward
    http://www.anasoft.co.uk
  8. Jamie
    Jamie Guest
    the idea is to compare the 2 signals which will produce a
    reference that will force a VCO (voltage control osc) to bias
    it self, there by adjusting one of the 2 signals to properly
    get in phase (in timing) with the master reference.
    the master ref is generally fixed, you use dividers of the
    VCO to scale it, so that the results will match the master ref.
    the end results is, the VCO increasing in Freq.
    the phase detector will produce the signal due to the 2
    signals not being phased.
    using something like an XOR gate circuit, there by pumping in
    the two references, one from the Master ref and the other from the
    output of the divider, will produce an sharp response of an out of
    phase signal there by creating biasing to push the VCO OSC up in freq
    until the two match and near match.
    normally the VCO is aligned in free run to pull it self below the
    minimum requirement. that is, with the bias voltage below what the
    Phase Detector will produce.
    a cheap PLL will use a simple charge pump decoupling circuit to hold
    the VCO. good ones use DAC with a small charge pump for a narrow window.
    etc..
  9. Active8
    Active8 Guest
    I think we're talking about the kind of periodic sigs where it is.
  10. But not in general:)
    If f1 is not rational to f2, phase can't be defined, even if periodic.
    Kevin Aylward
  11. Peter Lawton
    Peter Lawton Guest
    Mm...... depends what you mean by 'in phase'.
    Can you give me a definition to mull over?
    Peter
  12. jim
    jim Guest
    I'm pretty visually oriented so my questions come from that angle,
    so I'm picturing the output of a pll of two signals that are
    identical in frequency which will be a flat dc level. Does the whole
    loop then try to bring the dc level to zero or is matching frequencies
    enough?
    I can picture the visual way to obtain phase difference of two
    different frequencies of equal amplitude by just drawing a horizontal
    line through the two waves at any amplitude and this will give the
    rolling phase difference. But what will be the effect on the phase
    detector output if one of the waves is say twice the amplitude.? If
    there is a difference how does the phase detector deal with this?
    Thanks for all the replies btw, I've just got to get my hands on a
    phase detector and see for myself. jim
  13. John Larkin
    John Larkin Guest
    If there's just some DC gain from the pd output to the vco input
    (maybe just g=1, even), the loop will usually settle with some
    non-zero pd output, namely the voltage necessary to pull the vco to
    the target frequency. Since it almost always takes some non-zero dc
    voltage to pull the vco to the target, there must be a steady-state
    phase error, so the waveforms are locked in frequency but have some
    fixed phase offset, whatever it takes to tune the vco. This is a
    first-order pll.
    But if you add an integrator in the path from the phase detector
    output to the vco input, the loop will settle at zero frequency error
    and zero phase error (ignoring any residual offset errors in the pd or
    the integrator.) The integrator will slowly creep the vco input over
    time such as to servo the pd output to zero. This is a second-order
    pll.
    The vco-phase detector combination is itself mathematically an
    integrator - just imagine applying a small DC voltage at the vco
    input... the pd output will then be a ramp (although the ramp
    eventually folds over, but that's another story... no integrator can
    ramp forever!) So the type-1 servo loop is an integrator with negative
    feedback, which is usually very stable. The type 2 loop has *two*
    integrators in a feedback loop, which tends to be unstable,
    oscillating or ringing badly (two integrators tend to chase each
    others' tails, so to speak) so some additional compensation is needed
    to keep the lock stable.
    Beyond this, a good book on pll's would be helpful. Unfortunately,
    many are mainly mathematical in approach, which is fine for coming to
    workable solutions but somewhat lacking if you want an instinctive
    visual feel for what's happening.
    My favorite pll uses a d-type flipflop as the phase detector in a
    type-1 loop. It's inherently stable, but has zero phase error, because
    the phase detector gain is infinite. Mathematically, it's sort of a
    mess.
    Some phase detectors (like a linear multiplier) give an output that
    depends on one or both input amplitudes, so loop behavior varies with
    input signal level (vco level is usually pretty much constant.) Most
    pd's don't care about input amplitude for reasonable input levels, but
    just compare phases; that simplifies loop analysis. An XOR gate is a
    nice phase detector that pretty much ignores input level. Just imagine
    turning either sine input into a square wave of, say, +-1 volt fixed
    signal level, using a comparator or some such, and then comparing
    phases.
    John
  14. peterken
    peterken Guest
    the feedback signal to the vco will be of such a kind so the vco adjusts its
    frequency (phase) to the given input
    for one vco it will be a digital signal, for the other it will be a dc
    signal of a specific magnitude
    amplitudes are irrelevant - if above a given minimum of course, only a
    specific zero-crossing will be taken into acount
    usually this crossing is detected by (internal) comparators, or (if digital)
    square signals need to be fed
  15. peterken
    peterken Guest
    wrong
    It is indeed true the amplitude will be zero for both after one cycle of the
    5Hz signal, and the zero crossing will have the same direction
    BUT
    For a 5 and 10Hz signal that start off in phase the 5Hz signal will be
    lagging a full 360deg (or 2*pi rad) after one cycle with respect to the 10Hz
    signal.
    It's PHASE to be considered, remember...
  16. Active8
    Active8 Guest
    You mean a division resulting in a remainder of zero, that simple,
    eh? Sounds right to me.
  17. Active8
    Active8 Guest
    You both got me. The zero crosses don't indicate phase, they just
    coincide at integral multiples of full cycle phase differences.
  18. jim
    jim Guest
    So is this correct....... That one can measure phase difference of two
    different frequencies and amplitudes by picking any arbitrary
    amplitude on the scope and just running a horizontal line through the
    two waves and noting the intersection points? the complete phase curve
    can then be obtained by raising or lowering the reference point ? But
    what if one wave has twice the amplitude of the other? the horizontal
    line will only intersect it and not the other. Does this imply that
    only waves with equal amplitude can be measured for phase difference?
    jim
  19. peterken
    peterken Guest
    One can take ANY reference point on two signals (eg 20deg after a positive
    zero crossing of a single cycle or something like that), but easiest is to
    take zero crossing of course.
    When taking a reference for phase it's good practice to take something both
    signals DO have, in this case zero crossing.
    This way one can compare phases between any form of repetitive signals of
    whatever amplitude since it's phase we are interested in...
    As fo the "horizontal line" : adjust your scope (or other visualisation
    means) so the displayed amplitude of both is equal, since that's not what we
    are interested in measuring
  20. jim
    jim Guest
    Ok, I'm just about there,so you're saying that amplitude variation has
    no effect on the phase relationships?
