PLL and clock in altera cyclone 2 fpga
Discussion in 'Electronic Design' started by Jamie Morken, Dec 20, 2008.
  1. Jamie Morken
    Jamie Morken Guest
    I am using a cyclone 2 FPGA, and have a propagation delay warning in one
    of the megafunction's, lpm_divide. If we use a slower clock to this
    block it will work properly, but the system clock is 27MHz which is too
    fast for the bit width's of the numerator and denominator even with
    pipelining selected in lpm_divide. I haven't used the cyclone PLL
    before, but its lowest output frequency is 10MHz which is still a bit
    higher than I would like to run the lpm_divide at. I could add another
    external crystal, but I was wondering if it is possible to generate a
    logic clock inside the FPGA by using flipflops etc. I have been told
    that this is a bad idea to clock this way due to logic glitches, but am
    not sure why or if that is true?
    cheers,
    Jamie
  2. Frank Buss
    Frank Buss Guest
    You can use the megawizard to change the PLL, I think it allows multiple
    clock outputs (in Cyclone 3 more than 2, but I think it was at least 2 in
    Cyclone 2, too).
    How fast do you need to divide? Once I had a similar problem, but with
    LPM_MULT, because I needed some large bitwidths, but only at low frequency,
    so I implemented it serially myself like this, for signed multiplications:
    LIBRARY ieee;
    USE ieee.std_logic_1164.all;
    USE ieee.std_logic_arith.all;
    USE ieee.std_logic_unsigned.all;
    ENTITY Multiplier IS
    PORT(
    reset : IN STD_LOGIC;
    Clock : IN STD_LOGIC;
    Factor1In : IN STD_LOGIC_VECTOR (23 downto 0);
    Factor2In : IN STD_LOGIC_VECTOR (15 downto 0);
    ProductOut : OUT STD_LOGIC_VECTOR (23 downto 0);
    StartMultiplication : IN STD_LOGIC;
    Completed : OUT STD_LOGIC
    END Multiplier;
    ARCHITECTURE logic OF Multiplier IS
    SIGNAL Factor1 : SIGNED (39 downto 0);
    SIGNAL Factor2 : STD_LOGIC_VECTOR (15 downto 0);
    SIGNAL Counter : integer range 0 to 16;
    type StateType is (WAIT_FOR_START, ADD, COPY_OUTPUT);
    SIGNAL Product : SIGNED(39 downto 0);
    SIGNAL State : StateType := WAIT_FOR_START;
    BEGIN
    PROCESS (reset, Clock)
    VARIABLE temp : STD_LOGIC_VECTOR(39 downto 0);
    BEGIN
    IF (reset = '1') THEN
    State <= WAIT_FOR_START;
    ELSIF (rising_edge(Clock)) THEN
    Completed <= '0';
    case State is
    when WAIT_FOR_START =>
    if StartMultiplication = '1' then
    if Factor1In(23) = '1' then
    temp := '1' & x"ffff" & Factor1In(22 downto 0);
    else
    temp := '0' & x"0000" & Factor1In(22 downto 0);
    end if;
    Factor1 <= SIGNED(temp);
    Factor2 <= Factor2In;
    Counter <= 15;
    Product <= (others => '0');
    State <= ADD;
    end if;
    when ADD =>
    if Factor2(0) = '1' then
    Product <= Product + Factor1;
    end if;
    Factor1 <= Factor1(39) & Factor1(37 downto 0) & '0';
    Factor2 <= '0' & Factor2(15 downto 1);
    if Counter = 0 then
    State <= COPY_OUTPUT;
    else
    Counter <= Counter - 1;
    end if;
    when COPY_OUTPUT =>
    temp := std_logic_vector(Product);
    ProductOut <= temp(39) & temp(36 downto 14);
    Completed <= '1';
    end case;
    END IF;
    END PROCESS;
    END ARCHITECTURE logic;
    If you don't need to perform your division at high frequency, you can
    implement it serially, too. The algorithm is very similar and I think you
    can use my code as a base. Take a look at this description:
    http://bgu.uniclass.co.il/cs07/uploader.php?file=division.pdf&id=18
    There are faster algorithms, but you'll need more LEs for it.
    Yes, generating clocks with logic is a bad idea, because usually they are
    not routed on the global clock nets inside the FPGA, so logic triggered
    from this clock on opposite sides of the chip could be out of synch.
