"Plgn Motor Error" on "TI Microlaser Plus" printer
Discussion in 'Electronic Repair' started by Sam Goldwasser, Feb 12, 2007.
  1. Ancient but it was working a year ago. :)
    Now, after a couple minutes, the red ERROR LED comes on with a high pitched
    beep and the LCD displays something like "Plgn Motor Error". Then, only
    powering off gets it to reset. Eventually, it may go through and print
    a page.
    Thanks for any info, though it's probably going to become parts.....
    --- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
    | Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
    ignored unless my full name AND either lasers or electronics is included in the
    subject line. Or, you can contact me via the Feedback Form in the FAQs.
  2. Bill Jeffrey
    Bill Jeffrey Guest
    Sam -
    I'm sure you have Googled around and found, as I did, that
    most answers are simply "Have it serviced". I did find one site saying
    that the meaning of the message is "A problem with the PSU, PCU, optical
    unit, or PSU door switch". Now, even I can diagnose and fix a door
    switch. Dunno about the rest.
    The fixyourownprinter.com site has a forum in which someone posted "I
    was able to make unit work breifly by tapping on the little PWB that
    monitors laser output (COPAL ELECTRONICS PU639T103)". In that case, it
    sounds like a bad connection, broken PCB trace - or bad door switch.
    Since this PCB monitors laser output, is it possible that some toner
    found its way onto the laser output window, or the sensor window?
    Sorry, nothing more.
    Bill Jeffrey
  3. Actually, that is useful. The meaning for "plgn" I believe is "polygon",
    so the scanner mirror motor. And, I believe that once, when closing the
    topp, the error did go away briefly. Considering that this printer gets hardly
    any use, reseating all connectors would probably be a worthwhile first step.
    Now to figure out how to get in there. :)
    Thanks!
