Please suggest what board should i use
Discussion in 'General Electronics Discussion' started by tarun71gaur, Feb 12, 2018.
  1. tarun71gaur
    tarun71gaur
    Feb 12, 2018
    Hi everyone
    I am a newbie . I have done a few basic Arduino projects. I want to make a clip on type IMU sensor with a digital display of X,Y and Z angles, want it to be a compact independent unit. My requirements are:
    1. A small arduino board powered by button cells or small lithium battery
    2. A small OLED screen which can display 3 lines.
    3. A small accurate IMU shield.
    I want the unit to be light weight and not larger than 2inches.
    PS: please also suggest if it is possible to pause the readings on the OLED display at a particular position of the IMU sensor by using a remote switch.
  2. Hopup
    Hopup
    227
    31
    Jul 5, 2015
    Arduino mini and nano are small boards so maybe you can use them. I don't know what kind of processing power you need but I assume 328 is good for your project.
  3. tarun71gaur
    tarun71gaur
    Feb 12, 2018
    thanks. I am tilting towards arduino pro mini. I intend to use 6050 IMU, with a monochrome LCD display. Powered by a button cell. Would it work?
  4. Hopup
    Hopup
    227
    31
    Jul 5, 2015
    Make sure that there are enough output/input pins for the IMU and the screen.
