Please recommend a great flashlight.
Discussion in 'Lighting' started by nyeyn, Mar 16, 2008.
  1. nyeyn
    nyeyn Guest
    We'd like to buy a flashlight that's rechargeable, is very bright and
    lasts a long time before fading, and is easy to carry. We'd like one for
    use around the home and garden/forest and another to keep in the car
    (that can be recharged in the car).
    Obviously there's a lot of factors involved: brightness/length of time
    before light fades and needs rechaging/quality of build-durability/cost.
    We bought one for about $20 that is very bright but after a few uses, the
    light starts to fade after 4 minutes. Hopefully we can do a lot better
    than that.
    To a certain extent you get what you pay for, and the very best
    flashlights will be very expensive but sometimes a lot of money will buy
    you crap compared to something less expensive.
    I'd like to hear what you would recommend for either under $30 or $30-
    $100.
    I couldn't locate any website where different flashlights are evaluated
    and compared. Do you know of one?
    Dealtextreme.com sells a lot of Chinese made flashights including many
    Cree flashlights but they offer hardly any descriptions that might help
    me.
    Thanks for any advice,
    Tony
  2. http://ledmuseum.home.att.net/ledleft.htm
    http://ledmuseum.home.att.net/menutop.htm#26 (links to other flashlight
    review sites)
    http://www.candlepowerforums.com
    - Don Klipstein ()
  3. Guest
    A standard Mag-Lite LED (about $30) in whatever size you prefer, and buy
    two sets of rechargeable batteries for it on your own. Advantage: In an
    emergency, or if you've just forgotten to charge it, you can drop in a
    set of alkaline batteries. The alkalines will "keep" much better than
    the rechargeables; you can throw a set of alkalines up on the shelf and
    get them down next year and they'll still be OK. Disadvantage: you'll
    have to physically swap the sets of batteries to recharge it; you can't
    recharge the batteries while they are still inside the flashlight.
    Lubricate the O-ring (and the threads) on the base cap with a little
    petroleum jelly or silicone oil to make this easier.
    Rechargeable Mag-Lite (about $80-$90), which for some reason is not yet
    offered in LED. Buy two that are the same size - one that includes a
    car charger (12 V DC) and one that includes a home charger (120 V AC).
    That way you can swap the flashlights around between chargers as
    required. You can get a kit that has both the 12 V DC and 120 V AC
    power cords, but it only has one charging cradle - there are two
    mounting brackets in the kit, so you _can_ move the charging cradle
    around, but it's a moderate PITA. If you have two charging cradles,
    you can just snap the flashlights in and out of them as needed.
    Alternative: A Coleman lantern. Okay, not exactly a flashlight, but is
    much brighter and can be "recharged" in a couple of minutes. You can't
    use it indoors, and you really need one of the clam-shell cases to
    conveniently transport it in the car. They can be "recharged" in the
    car if you are handy with an Okie credit card. :)
    Don Klipstein gave some good ones. Especially candlepowerforums; those
    folks are nuts about flashlights.
    Matt Roberds
  4. David Hopper
    David Hopper Guest
    At work I use a Streamlight SL-20XP/LED which does a great job for me.
    I use the LEDs most of the time and use the halogen side for extra
    brightness. The 40 hr battery life using the LED side means I don't
    have to worry if I forget to turn it off during the day. The drop in
    charger in the truck makes it ready to go at any time.
    http://www.streamlight.com/product/product.aspx?pid=89
  5. What is "very bright". I have Celestron Power Tank that I
    bought to power my telescope, but also occasionally use as a
    very powerful flashlight during emergencies. The Power Tank
    uses a 7 amp-hour lead acid battery as its power source and
    has a main lamp rated at 80,000 candlepower!
    See:
    http://www.telescopes.com/telescope...onpowertank12vpowersupply7amphour.cfm#details
    Vic Roberts
    http://www.RobertsResearchInc.com
    To reply via e-mail:
    replace xxx with vdr in the Reply to: address
    or use e-mail address listed at the Web site.
    This information is provided for educational purposes only.
    It may not be used in any publication or posted on any Web
    site without written permission.
  6. Tom Biasi
    Tom Biasi Guest
    Oh do I wish I could have one of those!
    Tom
  7. GregS
    GregS Guest
    I don't know if there are any good lights that have built in smart charging.
    The sure thing is to have separate cells and suitable chargers. Most
    all the chargers that stay plugged in will destroy the cells lifetime
    over a short time, a year or two. My favorite medium intensity
    LED light is the Dorcey 1 watt LED. Its small, fits in pocket, is reliable,
    less blue light, and cheap, $20 at Walmart. It lasts about 3 hours continious,
    but with my use its just seems not to die. Gradually fades out.
    You can always buy a Surefire for the best overall performane products.
    http://www.dorcy.com/products.aspx?c=35
  8. GregS
    GregS Guest
    Surefire do have SMARTCHARGERS. Most of the flashlights are over $100.
    greg
  9. Bill
    Bill Guest
    Check out this flashlight..
  10. zxcvbob
    zxcvbob Guest
    I bought a 3-AA cell Maglight with a "3W" LED (it can't possibly be 3
    watts) two years ago and it has become my favorite flashlight. A set of
    alkaline batteries seems to last forever, or for occasional heavy use I
    put NiMH rechargeables in it.
    I bought a little bit larger (so she won't lose it) LED flashlight for
    my teenage daughter to carry in her car. I don't remember what brand it
    is; Gordon or Dorcy, maybe. It has a 3W LED and uses 2 or 3 C cells.
    It's brighter than my Maglight -- perhaps because it has a larger more
    efficient reflector.
    There should be no need to use rechargeable batteries in an LED light
    with C or D cells.
  11. I would do a test run to see how bright it actually is after the amount
    of time that you will be away from anyplace to use a charger or get fresh
    batteries.
    AA alkaline batteries probably will make that unit produce light for 150
    hours. Question is, how much light at 149 hours? How much light at 75
    hours? How much light at 40 hours?
    - Don Klipstein ()
