Please identify the bulb.
Discussion in 'Datasheets, Manuals and Component Identification' started by Sanndeep, Sep 11, 2016.
  1. Sanndeep
    Sanndeep
    3
    Sep 11, 2016
    Hi all, what is the name of bulb being used in this night lamp?
  2. davenn
    davenn Moderator
    13,576
    1,866
    pic too blurry and not enough info
    what is it's voltage and wattage ratings ?
  3. Sanndeep
    Sanndeep
    3
    Sep 11, 2016
    Hope this pic helps.. it is connected to mains. Used in night lamp.
  4. Bluejets
    Bluejets
    4,045
    843
    Oct 5, 2014
    That type of socket should not have any connection to mains supply.
    As far as I can see it is a ceramic base for an mr16 12v dichoric lamp.
  5. 73's de Edd
    73's de Edd
    2,870
    1,216
    Aug 21, 2015
    Sir Sanndeep. . . . . . .
    I also heartily agree on Sir Bluejets estimation of the type of bulb being utilized . . . . .it's a' looka like a' dis:
    Bi Pin Lamp:
    I only know of that lamp type being rated at up to 120VAC
    (Do note that THIS particular lamp set would be far above the "nite-lite" illumination level )
    REFERENCE:
    https://www.1000bulbs.com/category/120-130-volt-gy8-base-halogen-xenon-light-bulbs/
    BUT . . .with there being TWO lamps involved, that might also require either the use of a DVM in AC voltage test mode and read the voltage coming into the recessed pins of the the ceramic/porcelain hi temp socket.
    They might be wired in series. That would then work . . . . . with two series lamps . . . . . consuming 240VAC.
    OR a wall wart type of power supply plug in, MIGHT be involved in the supply of a lower voltage to power those lamps.
    It should be have its reduced voltage designated on its housing and give the voltage as well as current or KVA spec.
    Thaaaaasit . . . . . .
    73's de Edd
    Sanndeep likes this.
  6. Sanndeep
    Sanndeep
    3
    Sep 11, 2016
    Thank a tonne Sir..
