please help
Discussion in 'General Electronics Discussion' started by hoolko, Sep 16, 2013.
  1. hoolko
    hoolko
    14
    Mar 14, 2013
    newbie here....i have a 90vdc motor...1/4 hp and weighs about 17 pounds...for power i have an ac to dc speed controller rated 0-90 vdc,,,,when hooked up works but seems to be under powered, specially with the high torque motor has,,,,should i have a 100vdc power supply cause of the power drop ive heard about? also, does anyone know where i can buy a simple(?) ac to dc power supply(non adjustable) to use? i need inexpensive...my current ac to dc adjustable power supply cos about $35 thankyou, Nick
  2. shrtrnd
    shrtrnd
    3,827
    524
    Jan 15, 2010
    Do you have a drag on the rotation? Is this an old used motor, with possible bad
    bearings? Is the motor getting unusually hot during operation?
  3. hoolko
    hoolko
    14
    Mar 14, 2013
    thanks...brand new $125 motor......no heat.....i think i need 100vdc input???
  4. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    Is your power supply big enough?
    The motor will take about 2A so you need a power supply capable of 3A or so.
  5. shrtrnd
    shrtrnd
    3,827
    524
    Jan 15, 2010
    Good advice from duke37.
    With a new motor, your problem is more likely a current issue, than a voltage one.
