Hi Everyone,
I want my circuit to control the temperature so when the temperature falls below 20 d celcius the heater would come on and when the temperature reached 25 it would switch the radiator off.
I want to use low cost components and the oil filled radiator I already have to achieve this project.
I have already researched the way I want my circuit to measure the temperature using a LM35 sensor. Please see attached diagram.
What I need to know is what relay I would have to use, and where to connect it to allow the radiator to turn on and off.
Also if I would be better using a PC based system, micro controlled system or a control switch system. Please give pros and cons.
Thanks a lot guys
Thanks a lot guys
