Please help with plans
Discussion in 'Electronic Basics' started by j, Nov 7, 2003.
  1. j
    j Guest
    Hi hope I've found the right place to ask this. I'm looking for plans
    for a device that someone with little experience can follow (well I can
    use a soldering iron but that's about it). What I'm looking for is a
    more sufisticated version of this:
    http://www.sears.com/sr/javasr/prod...s&vertical=TOOL&pid=00924031000&bidsite=CRAFT
    The problem with this device is that it only works on 110 volts and only
    supports a small number of amps total pull. I'd like to be able to use
    sepperate circuits for both the tool and the accesory and different
    voltages.
    I have a 220 volt table saw and i want to turn my 110 volt dust
    collector on when the table saw is turned on and off whe the talbe saw
    gets turned off. I think it would be really nice if I could add an
    adjustable time delay so that I could set a number of seconds, say 5 -
    10, and shut off the dust collectdor after the table saw.
    thanks
    jw
    jw_nyc at yahoo dot com
