O
Owen Lawrence
Hi. I'm trying to design a circuit using a PIC and some home-grown
H-bridges (i.e. 4 transistors each) to drive a bipolar stepper motor. There
are few other things on the board, but my question is about how I should
position the components. I'm using Eagle, and when I autoroute, it finds
most paths it needs to, but the result is ugly. There are lines going under
components all over the place, lines inbetween the pins of the IC, etc.
Since I want to etch this board myself I'm not confident of the results if
so many lines have to be close to each other.
Do you have any advice about how I should do the layout? I started with
the ratsnest view, and positioned components roughly where I thought they'd
cause the least amount of positional interference. But now I've been
fiddling with it for a couple of evenings, and while I'm making progress,
I'm not sure this is the best way. I honestly thought I'd have it finished
long ago.
How much time does one usually spend working on the board layout, after
the schematic is designed? I'm still adding things to the design. Also,
what do you usually do with V+ and V-? I think these are the sources of
many of the strange routes I'm getting, since so many components have to
attach to them. Is there a layout technique you use?
Thanks for your help.
- Owen -
long ago.
- Owen -
