G
Gibbo
Homer said:No, the big red blob is clearly an MOV.
The big red blob is *clearly* a thermistor.
Gibbo said:The big red blob is *clearly* a thermistor.
I think that is what i said, that the red thinggie is truly a MOV,
but if you look at the designations at tbe bottom of the board where
there are *no* "space limitations", the R and Z designators are
bass-ackwards.
It's a Sg-Gap sg99b3en.
That pretty much takes care of that - it's a MLCC in a glass package.
Maybe designed to be very lossy, like a whole snubber in one 2-pin part.
Cheers!
Rich
Stan said:I'm 99% certain the red thinggie is not a MOV but a thermistor. It has
markings "Sincera 8R0M", I have removed it from the PCB and at room
temperature it has a low resistance of 8 Ohm, when hot (left on heater
for a while) i measured it at 80 Ohm's. So..i don't think the R & Z
designators are switched because using a "Z" designator for a
thermistor would be very odd. I'm certain Z801 is the correct
designator for the mystery component.
Do you have a datasheet or URL to find further information?
I did a search and found a couple of TV service manuals which appear
to use such a device but no useful information.Who manufacturers that
component? The manual was for a Toshiba but i couldn't find the
component on Toshiba's semiconductor site. Thanks..Stan
It's a suppressor diode made by General Semiconductor, they got bought?? A search on all of that or either half gave nothing.
Whazzit?- Hide quoted text -
You could be right, i will look into this. Thanks
I agree.Eeyore said:Gibbo wrote:
Clearly from function too.
The Z symbol on the solder resist side of the pcb is clearly a TVS to me.
http://en.wikipedia.org/wiki/Transient_voltage_suppression_diode
http://upload.wikimedia.org/wikiped...ient_voltage_suppression_diode_symbol.svg.png
Graham
Robert said:I agree.
Also, the designations are bass ackwards as i mentioned
Look rather carefully; one part is close to the side of the relay andEeyore said:Robert Baer wrote:
If you correct for the 'upside-down' ness of looking at the resist side, there's nothing wrong with the pcb legending at all !
Graham
Robert said:Look rather carefully; one part is close to the side of the relay and
both leads are "within" the relay length; the other is further away and
mostly off the "end" of the relay.
