Please help me identify this capacitor
Discussion in 'General Electronics Discussion' started by Phil1974, Jul 28, 2014.
  1. Phil1974
    Phil1974
    3
    Jul 28, 2014
    Sorry if this is in the wrong forum, I just need an answer on this pretty quick so I can order one, and this seemed most active. Basically, I just need to replace this, I am no expert but I looked on ebay under 476 16V and none seemed to match and a lot were pictured upside down, unhelpfully. Which capacitor is this please?
  2. davenn
    davenn Moderator
    13,793
    1,938
    hi Phil
    welcome to Electronics point
    its a 47uF 16V capacitor
    474 = 0.47uF
    475 = 4.7uF
    476 = 47uF
    cheers
  3. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Also it's a Tantalum capacitor so you have to check on the package size. Tantalum capacitors come in packages in either dimension format or case size like A,B,C and D. Unfortunately you can get the same value of capacitance and the same voltage rating in different sizes so you need to check before you buy.
    Adam
  4. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Yes, 47 µF, 16V tantalum capacitor in SMT package. The K may indicate Kemet manufacturer. These are available in several sizes. Measure the dimensions and see which is the closest match.
    Size code C: 6.0 × 3.2 mm, 2.8 mm high
    Size code D: 7.3 × 4.3 mm, 3.1 mm high
    Size code V: 7.3 × 4.3 mm, 2.0 mm high
    Tantalum capacitors are known to be unreliable and cheap no-brand ones are likely to be worse than others. I wouldn't trust an anonymous supplier on eBay; Digikey will supply a genuine part. Their selection guide: http://www.digikey.com/product-search/en?FV=fff40002,fff8000a,fffc018f,c0003,14000c,3400ba,380009,1140003,2dc155c&ColumnSort=987&stock=1
    Adam: Snap!
  5. Phil1974
    Phil1974
    3
    Jul 28, 2014
    That is great guys, thank you, its a size C. Do you know what the writing down the side means, it looks like W0 or is it an Ohm symbol and 84? :confused:
  6. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    According to the Kemet data sheets (yes, the K symbol means Kemet), "WO" is the date code - the "O" means October, but "W" doesn't match any of the year letters listed on the data sheet, which cover 2009~2014, and "84" is described as an "internal code", which means that it means something, but they don't want to tell us what.
  7. Phil1974
    Phil1974
    3
    Jul 28, 2014
    thanks, that's great :)
  8. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    It looks like it is a B45 series and W = 2008.
    Adam
