Please help me identify this burnt piece
Zip112
Nov 16, 2015
18
Nov 16, 2015
18
More pictures and questions...
On the top of the unit there's a chart describing the model specs. Obviously the first number is the voltage, but do you think the 2nd number is significant in terms of specs? In this cause they have the first box checked, which shows the numbers: "12-2500".
Do you think it would be fairly simple to build something like this from scratch using ebay parts, if using the same metal enclosure? It looks like it's just a switch, a fan, and the heating element. They charge over $300 for a piece like this, whereas I read on another post that the units are usually much weaker than a $10 hair dryer.
Tha fios agaibh
Aug 11, 2014
2,252
Aug 11, 2014
2,252
Those connectors are garbage too.
Well, for the heavy current used by a heater anyway.
Zip112
Nov 16, 2015
18
Nov 16, 2015
18
BTW, I just took it down because I have to clean it out. There's even a wasps nest in there! I'm thinking it's not going to last long (it's 3 years old).
Martaine2005
May 12, 2015
4,953
May 12, 2015
4,953
Which is why I showed a pic of the appropriate connector for a vehicle.
Called a scotch block...Don't know why though:eek:
But they are certainly bigger gauge metal contacts..
Martin
Tha fios agaibh
Aug 11, 2014
2,252
Aug 11, 2014
2,252
2nd number is most likely wattage.
You could probably just rewire what you have provided you are confident in doing so.
Tha fios agaibh
Aug 11, 2014
2,252
Aug 11, 2014
2,252
I would never use scotch blocks for any significant load. They work by piercing the stranded conductors and fatigue after a while. Especially if the current is high. Another problem is their tendancy to corrode.
Zip112
Nov 16, 2015
18
Nov 16, 2015
18
Is it really that bad to use just simple wire nuts with electrical tape over them?
Martaine2005
May 12, 2015
4,953
May 12, 2015
4,953
Hey John,
I agree again. I only joined in the conservation for a bit of banter. Any load would use relays and screwed connections IMHO.
Martin
Martaine2005
May 12, 2015
4,953
May 12, 2015
4,953
Not if the amperage is small. Heaters in cars are power hungry. High amp accessories need terminating properly.
Martin
Zip112
Nov 16, 2015
18
Nov 16, 2015
18
So do you guys agree that for a 12v 2,500 watt heater, it would be best to use the ring connectors that tha fios pointed out, with nuts and bolts holding them together?
Martaine2005
May 12, 2015
4,953
May 12, 2015
4,953
Hi Zip,
Yes, absolutely. What John suggested is by far the best way to connect high amperage accessories with out a doubt.
In fact, the bigger the better...
Martin
Tha fios agaibh
Aug 11, 2014
2,252
Aug 11, 2014
2,252
Ideally, yes. You could get by with wire nuts, but its not ideal. The plastic of the wire nut may not be rated for the ambient temperature, and corrosion can enter the splice if you dont use tape or shrink wrap.
Zip112
Nov 16, 2015
18
Nov 16, 2015
18
Thanks everyone.
If I wanted to test this unit when separated from the tractor, could I just connect it to a spare standard 12v car battery which has been sufficiently charged? I've never worked with such high amperage on a 12v device before. I'll only have to test it for a few seconds.
davenn
14,264
14,264
(Don't know how to crop on android)
OK ... I would probably be in the same boat if I was on my phone ... presumably there must be graphics progs available ??
I have never investigated LOL
