Davieboiii
- May 1, 2016
- 2
- Joined
- May 1, 2016
- Messages
- 2
Hello
I have a hoverboard gyros that has broken a number of times. This has happened when I have calibrated the card.
You should obviously not activate the infrared sensor while it is calibrated or it will burn the IR component. Somehow, I pressed the pad on board which activates IR while calibration that has made that it does not react no more.
Now when i start the hoverboard the light is constand and no reaction whatsoever. When it works, it only lights up while standing on the hoverboard.
Now I wonder if you can tell which component on the card is "burned" when I calibrate it wrong. I was going to order only the part and solder it there by myself. Cost to much buying entire card each time this happends.
I post pictures on the card. It does not have many components, so it should not be so difficult for a knowledgeable person to identification component.
Grateful for answers!
