please help me about my ultrasonic project!please
Discussion in 'Electronic Basics' started by E.persia, Aug 12, 2007.
  1. E.persia
    E.persia Guest
    hi everybody
    excuse me Ihave a project about ultrasonic for measurment of distance
    beetween two cars!
    its not for avoidance of hit!it for reducing the speed to keep the
    standard distance between two car
    somy need is about 30 or 40 meters
    its very long distance but its two neccessary for me
    how can I do it
    I read somthing about horn but its ....
    you know its in a car!
    what a horn can be our what a car????
    accept my special thanks for your helps
  2. Sjouke Burry
    Sjouke Burry Guest
    We did this by useing an Israely IR laser with 10 cm reolution, and a serial
    RS232 output.
    We implemented a nice car following experiment with that.
    (and no, I am not allowed to tell more about it :) :) )
  3. BobG
    BobG Guest
    Put a red laser on a stepper motor so it will rotate left and right.
    Put this near the right headlight. Put a receiver near the left
    headlight. Park the car with the laser X feet behind another car. Turn
    on the laser, step the laser to the left until the reflection hits the
    receiver. The number steps gives an angle, and the distance between
    the laser and receiver is known. Should be able to calc distance X.
  4. E.persia
    E.persia Guest
    sorry may be it's the second choice but my final project is about
    ultrasonic amplifying to 50 meter!
  5. Chris
    Chris Guest
    Hi, Erfan. The basic principle of ultrasonics is sending out a brief
    sound, then measuring the time until first echo. Using some quick
    math (sound travels about 150 microseconds per inch), you can
    determine the distance of the object that caused the echo.
    Simple, and you probably know this. But there's another basic
    physical fact -- the inverse square law also applies to acoustics.
    That means you're going to need an awfully loud ultrasonic chirp (more
    like the chirp of the largest pterodactyl that ever lived) to get a
    reasonable echo at 80 meters total. Hence the horn, I guess.
    In additioon, your sound is going to have to be filtered from the
    noise of air rushing past the transducer (both cars are moving at a
    reasonable speed).
    I'd guess the best advice someone could give you would be to focus on
    another method of determining distance.
    Good luck
    Chris
  6. BobG
    BobG Guest
    Does it HAVE to be ultrasonic? Those 3.5" tweeters can take about 25V
    RMS and probably have peak acoustic output at about 3.5KHz... but if
    you just beeped it for 10ms every 100ms it might not be too annoying.
    At least if you can hear it, you can test it with a regular microphone.
  7. Rich Grise
    Rich Grise Guest
