please help if you can
I have a Zenith system 3 TV model #SY2593P made in august 1982
It has been a good tv until yesterday when the pictuers went all fuzzy
on me you can still see and hear it its just all fuzzy and static
looking I have a Cabel box hooked up to it and i was wondering if
anyone had any ideas on whats wrong with it and any possible
solutions
Things ive tried is Hooking the cable box to a different tv (pic came
in fine on the other Tv)
ive tried other wires still fuzzy pic on Zenith
Thanks for the help
C
clifto
solutions
As near as I can make out, it's a problem with the antenna connections
or the tuner.
Jeroni Paul
The focus voltage has gone low or dead. This is a quite high voltage
around 5 kV, not a place for hobbyists or starters. It could be the
flyback focus pot is bad or open, or if the set uses a tripler they
used to fail that way. You might try slightly moving the focus pot and
see if it goes out of the bad spot.
solutions
Thanks for the help
too vague, do you mean focus is bad? or picture has gone snowy? Or
nowt but snow?
NT
