I have a boat motor I restored from 1966, it was one of the first with electronic switchbox for the ignition. Mercury thunderbolt brand. the rectifier is bad, these old parts are hard to find and expensive. the rectifier is in a small metal case that grounds through the case. it has three connection points other than the case for ground. two connections come from the stator/alternator and one feeds dc to the battery/ignition I don't believe there is a voltage regulator in the circuit but it does charge the battery I believe. I took out all the old epoxy and have all the parts out. I have included a rough drawing with pictures of the components. two diodes are grounded at the case and connect to the stator leads(yellow) another component is connected from the stator leads to the 12 v positive output terminal but they have no markings for identification, I assume they are diodes also and there is a capacitor connected from the case to the 12v positive also. the stator is rated at 8 amps at full speed.
my questions;
why does the rectifier need the diodes from the case to the stator input wires
are the unmarked components in the middle diodes also
why does the circuit need the capacitor
can I replace these components with new diodes of what specific kind
what does full wave rectifier mean
my questions;
